Hello, I have a Z8 box, occasionally when I want to open the channel list and change channels, or when I want to switch to live channels from Vod movies, the screen turns black and the channels do not open. Channels open when I disconnect and reconnect. I tried everything on the forum, deleting the cache, resetting the box to factory settings. But unfortunately, there was no solution. I've also tried the Xtream api and the Mac portal, but it's always the same. I wonder if you can help me.
Formuler Z8 Portal disconnection
kazemx -
October 5, 2020 at 2:30 PM -
Hi
here are allot of wich have the same issue incl myself. It is sinds the last update 26.8.
a later hotfix didnt solver the issue.
so we all are waiting for Update because everything worked wel before 26.8 update.
same story here, do not understand why we cannot roll back to older version thats work
also do not understand why rollout a FW or HOTfix before testing , and why is it OUR risk if we update the release software, we trust the
enigineer who create the FW or Hotfix.
So take a beer, and wait......
also lessons learn I WILL NOT UDATE anymore
Pinnoes
Are you all using a vpn. If not get one
Hi Den 123,
i am not using vpn before, so why i must used now?
i installds tivimate and this works on the Z8 so the problem is in mytvOnline2
Pinnoes
Hi Den 123,
Pinnoes
yes i think so the same
Load surfshark free trial vpn Use wireguard.
I don't think vpn has anything to do with this problem. Unless it's the isp that blocks iptv....
I have found it will make difference free trial 30days cost you nothing
I use vpn, tried a few, but I've found a big difference in speed if i get a vpn from my own country with lots of servers to choose from.
Surfshark were slow for me even if I used a server here. Nordvpn was fast but some of their servers were blocked by my provider and even by fast.com...
I'm trying a native vpn now and get real good speed from the z8, 220/90 out of a 250/100 fiber line....
Surfshark. You have got to use the wireguard. In it. It’s faster than Nord. It’s the fastest. Also free 30day trial you can also set to multi hop
I only use wireguard. You can't say one is faster than the other for everyone. Different vpn's are better or worse in different locations of the world.
I have tried Surfshark, for me it was not the fastest by any means. Nordvpn was a lot faster altough it had other negative aspects.
Where I live I've found 2 other vpn providers that gave me maximum speed and really good demerit policies. For example servers without harddrives which mean they can't even log traffic...
So yeah, I suggest trying out different ones and see which one fit your needs and location best.
Ok good luck
Same issue here
Not using vpn
Should not be the first one to update in future!
I have the same problem and its not related to VPN as I have tried that for months, it started for me in summer and even after several factory resets and all kind of setups it still looses image after a while. It can run fine for 3-4 hours and at worst times it stops 10 times a hour.
Questions for you:
Is Formuler aware of this problem?
In case they are, what did they say?
2 friends of mine have the Z8 also and they have the exact same problem as I do.
Bought a Formuler Z8 Pro and all is good but the Z8 is still with theese issues.
PLease help guys(and gals) and also calling for help from Admins
Sorry to say but this is not Formuler issue if the Provider is overloaded or the ISP have some issues.
Did you try other provider with 24h trial account?
Yes same with other providers. It is not ISP or provider. As I said I have 2 boxes at home and the Z8Pro is just fine but not the Z8. Same provider and ISP.
Please, in this case open a new support ticket at https://support.formuler.tv and provide detailed issue description. If necessary include also screenshots or small videos from the Issue. Write also that this only happen on Z8 and not on Z8 pro. Thank You.
Btw. I would also install the latest Beta and test.
I have the same problem, has this issue been solved?
Here the same issue.
Connection is 100% ok, VPN is avalaible but doesn't solve the problem.
The work-around is disconnect from the server and reconnect again. Having the same problem on multiple Z8 boxes and 2 different providers.
It would be nice when this issue is taken serious by the developer. -
Welcome to Forum
It would be nice when this issue is taken serious by the developer.amen !!!
Multiple Z8's here no problem with multiple providers
Welcome to Forum
Stumbled on another forum (and me the fool can't remember) and read about more people facing the same issue.
Seems to be more related to MyTVOnline2 then to the Formuler box. -
I think a lot of the problems are provider. It’s so easy to say it’s your formuler box. I would say 99% are provider.
You have said it several times Den123, just bollocks.
This is NOT an provider issue and that is more or less confirmed in several cases. No matter what, hopefully they solve it with next update.
Quite a "Professional" judgement.
In my case I have tested different apps on the Z8 without causing this problem
MTOL2 is for obvious reasons still the fav. pick but it is also the only one to have this nasty problem.I am not here to blast MTOL2. Like others I want to help to resolve this problem.
I disagree with this, because if the same provider works pretty much without issues on other devices how can you then say its 99% the provider?
In the last 2 weeks or something so many people have been complaining about this and you say its a providers issue. lol..
I have the same problem on Z8 and its not related to VPN as I have tried that for months, and even after several factory resets and all kind of setups it still looses image after a while. It can run fine for 3-4 hours and at worst times it stops 10 times a hour.
Not the provider OK with VLC on iPhone, the problem is MOL2...
Thanks for help
