What USB device (and size) would be recommended for best user experience on the GTV?
I would like to be able to record and pause live TV.
Thx,
Kris
Thx,
Kris
every USB Stick that can write 20mb sec. How big this should be depends from your recording behave. SSD is of course the best choice.
How much recording are you going to do / keep will help you decide what size storage you need.
Connect it to USB 3 port - so get a compatible storage device.
You should be able to choose from memory sticks to ssd drive m2 with an enclosure.
Assuming above is for IPTV, you could find a provider with 7 day catch up meaning you won't need to record.![]()
Really useful on weekends with live sports overlapping.
Youtube - How to add a portable SSD to the Formuler GTV Android TV by wolfey
Can we use a NAS for recording with the GTV ???
I think I read in the new year?
Is there a Network storage Icon on Home screen like on Z8
Try the following if you have the GTV
How to set Z8 and NAS for recording and timeshift over network.
Anyone come across a USB stick that does not need reformatting and is good to go straight out the box yet?
Any that has the following format
FAT32
NTFS
exFAT
See this guide
Why ?
Thanks, but that isn't what I asked. I am already aware of the supported formats and how to reformat using Rufus.
Why ?
Asking for a friend 😉
I've tried several and have had to reformat using Rufus if I've wanted to record. To actually plug in a USB with content to view, no need to format.
I only ask why because it's not a great deal to format and you know you won't go wrong if you start with format
I totally agree Rick. Like I said not asking for myself, asking for others.
Ps. What V8 do you have
OK. No V8 now I used to build Bikes and Trikes Rover SD1 auto's were my Favorite, legs either side of engine throttle on one foot brake on the other. Always
hard tailed
Few lengths of 38mm cold drawn steel tube front end off large bike and some foam for a seat.
arthritis in hands and everywhere else stopped my fun.
But at least I had some wild years not like some LOL
Sounds like a lot of fun mate.. and like you say, better to have been there and done it and have the memories than never at all 👍
Memories LOL
"No sleep till Sunday"
V8rick was better name, Knocked about with some crazy peeps did some stuff for them and they got me a Zippo(always had Embassy No1 in my mouth on bike or trike). it had MR on it
Mental Rick because of the way I lived and rode
Its for z8 for gtv does no apply. ...
