New MOL 2 9.2.6 for GTV released.
MYTVOnline 2 : 9.2.6
WARNING:
HowTo Install:
Home Menu -> Software Update app -> The Firmware and Software version is shown, press "OK" button for install.
We need to collect data and feedbacks on one place,please report in this thread only. Thank you for your understanding.
New Features, Fixes & Improvements:
- Increase Cloud Timeshift compatibility with more servers
- Display episode list in ascending order
- Add Cloud Timeshift shortcut to Classic channel list
- FIX: Can't play recording if system language is not English
- FIX: Crash when using certain m3u URL formats
- FIX: Grid EPG doesn't load until EPG is scrolled
- FIX: Frame rate not displayed sometimes
