can somebody from formuler answer me a simple question about this gtv
I have 3 boxes all have different settings how's that even possible same shipment all on the latest update ????????
mean the three new one have different settings? if i understood it right, which settings are differents?
Yes this would be good to know, at setup stage they are all with same standard settings.. Also, it is important the version from fw and sw to know.
there you go
Could u give me the pn and sn ? and when did u bought?
Jo there is a setting you have to do to get all ycb ect. Just can’t think what it was will let you no if I remember
can you do screen shot rather than a pic
Go to colour space setting. Click on it ok. You then get a list of all ones you can pick hope this helps
there you go
Don`t know what is shown on the pictures, 1 TV and 1 Monitor or 2 different TV`s? Did you check which Colour Settings are possible with this TV`s and how the TV is set?
Second do you use HDMi Cable on Tv (with only 1 setting) from the box or another cable?
Please check all in detail, test or change and report again.
thats two tvs hdmi cable
Both 4k just seems strange to me one box has one setting the other more options,
Is that the gtv detecting something different on one tv and giving more options 🤔
The HDMI shake (exchange data) between box and TV decide what is possible and what not. It is also very curios that your second TV (curved) shows only one possible setting, should at least show RGB too.
Test following:
Auto switch to best resolution: activate
Colour Depth Setting: ON
Reboot your box after this and restart your TV.
Colour Depth Settings: -> How much are now shown?
Test also with other HDMI 2.0 cable and check your TV depth colour settings.
You think two different tvs with different specifications must give you the same color space options?
No but was curious why one only had one setting the others had 3 as sam said I should have at least RGB aswell which I don't have
Display MoreThe HDMI shake (exchange data) between box and TV decide what is possible and what not. It is also very curios that your second TV (curved) shows only one possible setting, should at least show RGB too.
Test following:
Dosent even give me a option to turn on or off on colour depth setting
As for hdmi cables im using the best about cost more than the gtv audioquest cinnamon i have swapped cinnamon cables from other rooms to make sure
Would be interesting to see what happens, if you discount the GTV and swap the tv they were connected too.
Wonder if the options will change
Thought of that unfortunately i have same tv in all rooms
