Good day! I have a question about AFR. I suspect that when it's on, it matches the output frame rate to that of the input.
But what is the default frame rate of the output when AFR is off?
I've seen (via INFO)
1920 @ 60 fps
1280 @ 60 fps
1280 @ 30 fps
1280 @ 24 fps
864 @ 30 fps
Does it upscale low frame rates and downscale high frame rates when AFR is off and match them when it is on? ![]()
Thanks for any replies.
