I was in the usa for 2 months because of my studies, then bought the box there.
Now I'm back in Germany, connected the box and now the message comes: This product is not for sale outside North America ?? What can I do?
Did you try with factory reset?
Unfortunately, products sold in North Amercia are not available on other continents...
Are you serious?
But what can i do now?
I never realized boxes were region locked - when does that message appear, when trying to use MyTVOnline2 or ANY app on the device? For example, can Plex be used or is that locked out also? I was going to send a box to my sister in England for her birthday, but glad I read this thread first!
First time I hear about this, Mango please post a screenshot of the message.
Use a VPN and set it to use a VPN server in the USA.
You can try this:
No its not work.
I think the reseller has blocked all devices from usa of serial number.
Hello,im currently using Formuler z8 in Germany (bought it here it as well)
In summer im moving away to Brazil ,so it could be that i might have a problems also by using this box over seas ?
I cant find any info about this issue over internet.
Any advice.
And i didnt really understand if factory reset helps with this issue.
If this is true then I won't be surprised.
I also don't get why Formuler devices are possible to be limited by a reseller.
Not if it's a retail box.
I think CBP ADM told everything.
Your Box should work there.
QuoteFor all others with same problem
Follow the instruction in the image and contact your seller.
