  • Home screen > Power mode > Standby
    Use Standby mode instead of "Power off" mode to see if it works.
  • LG CX Oled..all CEC options enabled. My Z8 turns off fine when TV powers off but never turns on when I power on TV. Stays on standby. Any way to fix? thx
    Mine does reverse. All options enabled, everything turns off but 15 seconds later the Z8 powers on. I believe the Samsung TV is polling for devices.
    So I have "Turn on with TV" disabled and have to use 2 buttons (STB/TV) to start everybody up. Go figure.
    Peder
  • Mine does reverse. All options enabled, everything turns off but 15 seconds later the Z8 powers on. I believe the Samsung TV is polling for devices.
    I have exactly the same issue with my samsung tv but it's nothing to do with the Z8 because the tv does the same with my Ps4 Console.
