Official FW 1.4.80 - SW 7.10.2 for Z8 pro / Z8 / Z Alpha / Z+ neo (16.11.2020)
  • You spoke and we listened! We have just released new software for Z8 Pro, Z8, Z Alpha, and Z+ Neo.
    These release notes provide the most up-to-date information about new features, known issues, and improvements so please read them through for more information.
    One of the great things about the new software update is the filter only Favorites on Live. You can access this new function from the classic channel list by pressing the red key on the remote control.
    There are also more features that you have always wanted. You can now track progress and resume playback in Recordings and check the added date on VOD.
    We recommend users install this update to enjoy better features and more stable functionality.
    You can always download the free OTA software updates directly from your device using the built-in update app.
    Firmware Version : 1.4.80
    MYTVOnline 2 : 7.10.2
    WARNING:
    The install process and reboot works automatically! Please don`t turn off the box or unplug the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
    Fixes & Improvements:
    • NEW: Change system screenshot path. Home > Launcher Settings > Screenshot path
    • FIX: Z Alpha Bluetooth issue
    • FIX: Crash fix for some OTT apps
    • FIX: CEC on/off switch state not saved
    • FIX: Deployment tools bug that appeared in beta release. (Allow user portals parameter bug)
    • IMP: Updated system time zones
    • IMP: NAS mount now visible to other apps
    • IMP: Rename "HDMI Auto Adaption" & change behavior to "Auto-select BEST resolution"
    • IMP: Block incoming Bluetooth files. Use Android Settings > Security > Allow incoming BT requests: OFF
    • IMP: Disconnect and reconnect BT Audio devices without re-pairing
    • IMP: Updated remote deployment template
    • IMP: CEC: Wake up TV with Formuler. Wake up Formuler with TV (Must use Standby power mode)
    • IMP: Memory utilization optimizations
    New Features, Fixes & Improvements:
    • NEW: Live > Filter only Favorites. Activate from Classic Channel List > Filter (Red hotkey)
    • NEW: Recordings > track progress and resume playback
    • NEW: VOD Details > Date Added
    • NEW: Auto-detect API portal from m3u URL
    • FIX: Danish subtitle display issue
    • FIX: EPG offset issue with certain services
    • FIX: Audio Track Language not displayed for some contents
    • FIX: Menu navigation issue for services with no Live TV section
    • FIX: Issue with Maximum catchup (replay) days
    • FIX: picon display issues
    • FIX: Edit Groups > Cannot select certain Groups
    • FIX: Online subtitles not displayed immediately after download
    • FIX: Player controls do not timeout according to OSD Timeout parameter
    • FIX: Episode list scrolling issue on certain portals
    • FIX: VOD ends early if paused
    • FIX: Cannot delete new recordings
    • FIX: Opus audio playback issue
    • IMP: Opensubtitles > add all languages
      • Set preferred languages from Settings > Player Options > Online Subtitles
    • IMP: Cursor position automatically moved to last watched index in episode list
    • IMP: Improved Skip Ahead performance
    • IMP: Scheduled Recordings: Resolve single instance of series conflict
    • IMP: Warn before powering off if recording is in progress
    • NEW: Menu Translation: Slovenčina
    • IMP: Improved Swedish, French Translation (Thanks tvman, GoodGood)
  • This is official and not Beta. Reported bugs through beta are fixed in this official release.
  • my box is not connecting after the update, no signal says the tv but the led is green.
    any ideas?
  • I am not sure if this is known but playback from history is not working, after clicking the movie it does nothing , I see a loading circle for a very brief moment but it does not start, looking the movie up in my VOD's will play it back.
    I did no further testing yet and I also did not clean cache yet, I just tried to watch after the update was done.
    Is it Xc? or Stalker? m3u?
    I tried it but could not reproduce the issue.
    can you provide a video of the isuse?
    (Click Me) https://streamable.com/ > Upload the Image/Video file > Copy link > Paste the link with your reply.
  • is the tv supports CEC?
    explain the issue in more detail.
    Yes.
    Now I can control the box with my TV remote.
    When I shutdown my TV the box shutdown too.
    Only thing that doesn't work is when I start my box the TV don't start. Or vice versa.
    So, my TV supports CEC. (on my PS4 every option works great)
  • My Z8 is connected to my soundsystem (Yamaha RX-V485) via HDMI - CEC, so that the soundsystem automatically switches on when the Z8 box witches on (from standby) and the sound is transferred to the soundsystem. Before the update (to Beta and now) this official release, the sound was always transferred to the soundsystem at switch-on of the Z8, no issues ever.
    After the update I notice that although the soundsystem switches on, sometimes the sound is not being transferred to the soundsystem... The correct input source is selected, but no sound is coming in...
    Switching the Z8 off and back on again mostly resolves the issue...
    Advanced settings are:
    Enable CEC - ON
    Turn off with TV - ON
    Switch on with TV - ON
    Use TV remote controller - OFF
    Could this be the result of (a bug in) the new CEC: Turn on TV / Turn off TV option settings?
  • "One of the great things about the new software update is the filter only Favorites on Live. You can access this new function from the classic channel list by pressing the red key on the remote control."
    This does nothing different for me when I press red button
  • What needs to use standby power mode? Wake up TV with Formuler or Wake up Formuler with TV? Or both?
    Both. If box is powered off (call it deep standby and not normal standby), your TV will not go on if you start the box. If box was in standby and you activated " Turn on with TV" in the settings, the TV will go on if you start Z8 or vice versa.
    Scenario: You have in category 1 (10 favorites) and category 2 (20 favorites).
    If you press now red button in classic channel list, choose and press "Only Favorites" once again (symbol full) you will see in category 1 and 2 only your Favorites, other category`s would be empty because there are no favorite channels.. To go back, start Classic list, press again on "Only Favorites" (symbol half full) in your category`s are now shown all available channels.
  • Hello everyone, I just did the last update on my Z8 and since then there has been a lot of blocking. Before the update everything was working fine. Did you encounter the same problem? is there an adjustment to be made? this problem is only on the Z8 because on the Z8 Pro everything is OK.
    thank you for your support.
  • Please do factory reset if issues occur after such big and major update. Software cannot be rolled back after installation (is always shown in update thread and update process).
  • After trying to apply the latest update my Z8 is no longer functional. I have tried a factory reset (both methods with using the red button and pressing 1 and also with the factory reset tool and nothing has worked. I turn it on, i get the Z8 splash screen then the light on the front alternates from green to red for a couple minutes then stays green but I don't get a picture at all. It just shows a black screen. Does anyone have any recommendations on what to do, or is my box a paperweight now?
  • Is it Xc? or Stalker? m3u?
    my problem not able to playback history VOD's is solved, I did not reboot at all but it is not happening anymore after setting it on standby and retry the next day. I dont think its a bug as it only happened to me but wanted to report it here in case anyone had the same issue directly after the update.
    also I think I am using stalker but not sure, I make a connection to a provider (they call it portal), im not knowledgable about how they connection types are called :smiling_face:
    You have to be in the Classic Channel List menu for it to work.
    Please perform the following and tell what you see on your TV Screen and on the Front of the Z8 device:
    1. Unplug the power from your Formuler device for 1 minute
    2. Plug in the power to your Formuler device and observe the TV screen and the front status LED on the Formuler device.
    Upload the Image/Video file here and reply it with the link
  • After my Update, I have a Problem with my "Pairing process" Wirless controller PS4.
    The Pairing process don't work anymore but the device recognize my Controller.
    Advice: Formuler Z8 Pro
    Controller: PS4
    Thanks for the Support
    Make sure that it's working fine with another device.
    You paired it but didn't work? or you even could not pair it?
    What I find weird is that on my 1st Z8 I did a factory reset, then I put the configuration back with the enc2 file and for the moment it seems that it is ok. I did the same on my 2nd Z8 and it is still robotizing.
    it's really weird because before the update everything was ok. Hopefully another update can fix this kind of problem.
  • So far, no problems really to report with the new update, except sometimes (not sure when or what I've done) I get double entries of the same show, same time in the EPG.
    Is there a tutorial on this, or basically automatic once CEC is enabled on the TV? What if I'm programming the box to record a show while I'm asleep? Will the TV wake up too, or is there a way to disable this?
  • Formuler Z8 not working after update this week (17th November 2020)
    • Model: . Formuler 8
    • Firmware version: not sure; only 2 months old;
      MYTVOnline 1 / MYTVOnline 2 version: not sure – cannot get z8 to work in order to find this information.
    • Box connected with: Ethernet
    • What issue(s) are you having? My demands have been simple. I have not been using the Z8 to its full potential, just watching selected TV. However, I powered up on Tuesday 17th November to see that updates were ready for me. I downloaded and installed as directed but sadly my Z8 doesn’t work any more. Turning the device on gives me a green LED and a blue screen.
    • Did you factory reset your device? and when?: yes - both the inbuilt method using the red key on the RMU and the USB version using update.ird reset tool have failed.
    When I use the USB method, I get a splash of Z8 and get hopeful. Then I become even more hopeful when I get coloured rings in the centre of the screen and a progress bar below it. The bar progresses cheerfully from left to right to suggest 100% completion and then sadly nothing. The TV screen becomes blue. The LED light on the Z8 is flashing red/green during the initial phase and then just green. I was very patient and waited over 30 minutes but nothing changed. I have tried this three times now with the same result.
    I would be grateful for any advice that would help.
    Thanks in anticipation.
    Mark
  • The TV screen becomes blue. The LED light on the Z8 is flashing red/green during the initial phase and then just green.
    LED light say us the box rebooted and started the launcher. Can you upload screenshot from your blue screen?
    Check also your HDMI Cable if connected properly (Box and TV), second hold resolution button for at least few seconds and few times to see if something change.
  • Make sure that it's working fine with another device.
    At first thankyou for the fast Support :smiling_face:
    The normal pairing process don't work anymore "maybe i do it wrong :smiling_face: "
    -> Push de PS Button
    -> The Formuler advice recognize the controller
    -> Pairing "Yes"
    -> Don't work
    only this way works by me:
    -> Search for Bluetooth advice
    -> Push "PS Button + Share + L2" (than the light blinks faster than normal on the Controller)
    -> The Formuler device recognice the controller
    -> Pairing "yes"
    -> That work's
