How to download online subtitles and use this in MOL2.
Please see pictures and follow description inside.
TRIED IT DOESN'T WORK
Where can I find User ID
Doesn’t work even if you allready have a account.
Same for me too.
I get the message:
”Error while signing in. Check username and password or try again later. (-1)”
Even when i try to create a new account.
Manually create a new account on opensubtitles.org website and try again
Change an User ID and E-mail address when you get the error message and try again.
after you signed up the account, please activate the account in your email.
and When you log in, you have to choose <Sign-in> option, not the <Sign-out> option.
works fine for me. Good feature to have, would be good if we could somehow get subtitles for live channels too. I didn't have to sign into subtitle websites. It seems to find it from somewhere.
what I would like to know is how to change the size of the subtitles or position it lower down. Please let me know if anyone knows. Thanks.
How do i search for subs if i want them in danish?, as i see it, it only works for language that Mol2 is translated to.
set mine up today and works great.
Instructions spot on 👍
Works very good. 😊
If you use VPN turn it off and it will work
I use a VPN and mine works fine
Formuler released a software hotfix for your issue today.
Please update the software on your device using the software update app on the Home screen.
works very well🤟
i have 2 account a new and an old none of them work
Excellent. Thank you for this.
Step by step is perfect.
I seem to only get the "error while signing in" message when I don't put in the correct name of the movie.
Sometimes the icon photo of the movie says one name but the text name under it is something else.
Movies get released earlier in other countries than in mine and they go by a different name, so I need to find the real name then search for the CC and all works well.
I don't understand why it does this, but it works for me.
i get 401
where are you seeing the "401" exactly?
which menu?
when i try to download sub i get this sign
401 means Unauthorized. Check if you are logged in or create new account, log in and try again.
