Beta update - Firmware v. 11.2.8 and MOL 3 v. 11.2.32 for Formuler Z11 Series released.
  • Hi,woste,your advice was right,i thankfully removed the App,the way you suggested!
    As far as EPG on XCAPI there doesnt seem to be a trend in the issue and highly variable outcomes per provider,suggesting that its not only box related,i cant get my head around it anymore.
  • I forgot in my list to mention something very important that was present and super useful in MOL2 but for some reason has been removed:
    When typing in the search fied, after each letter, the search automatically began, narrowing and fine tuning the search and now , you are forced to write a whole word, then go outside of the virtual keyboard and validate ...it takes a lot more time if you don't find or type the right word or make a typo, while on the other hand, by applying automatic search after each letter typed, you avoid this problem and you can just delete the last letter and the search will automatically show you what you want to see..even before typing the whole title or name.
    Thank you if you could "go back" to the automatic search while typing .
  • hello
    About EPG and content manager after startup in the morning:
    - yesterday EPG was updated for all providers (ok)
    - today EPG was updated for almost all providers (all except the last provider in the list, which still showed EPG updated the day before)
    Edit: a few hours later also EPG of the last provider in the list seems to have been updated automatically.
    Edited once, last by woste (November 18, 2023 at 1:21 PM).
  • Tonight i set a scheduled recording from 20.20 to 22.00hrs pm,in notifications it was reported as succesful,however ,after 8 minutes the recording ended abruptly.
    I used the same USB stick as i used in previous recordings,since the beta update,and they all were fully completed,asmentioned in notifications.
    How is it posssible that when a recording is noted as succesful-time started,time ended- and it is stopped abruptly on playback?
  • Story Tonight i set a scheduled recording from 20.20 to 22.00hrs pm,in notifications it was reported as succesful,however ,after 8 minutes the recording ended abruptly.
    Story of the formuler z11. Mine does it all the time. Did the same last night. Around 8/10 mins of a 4 hr boxing show 🤷🏼‍♂️ then straight to the usual home screen.
  • I noticed a new bug, don't know it it was there alreaydy before the beta:
    When you go in Content manager/ Content sources , and in the provider pannel you update a full content let's say from on oly France Channels to all the channels of all the countries availaible, idem for vod. and validate. Expect a few time for server refresh of the supplier pannel
    then you chose in MOL3 the provider (in sources) and right on top on the round arrow (the 1st top left ) called "refresh"... It is supposed to relaod the whole playlist isn't it?
    When refresh has been finished, the counter with the number of channels and CHANNELS and VOD HAS NOT changed , it has not updated.
    Is that normal?
    I then need to make refesh content by going back in the live channels channels or go to Content Data/Data Sync , then "Refresh", wait...but if I go back to sources, the counter has not changed either...even there is a "v" checked next to the portal name and we could think it's refreshed and updated...but no: we need finally to press the Menu key on the remote, then make "refresh contents" (on top of Live Channels) until complete, then, we can finally go back into content manager and content sources and finally see our counter updated.
    I think it shoud update itself just by doing a Refesh from the Content Sources pannel.
  • Since the beta update i did numerous scheduled recordings,most of them went well.
    However on three occasions either the recording was broken off early and one time there was no recording at all.
    Over the course of these recordings i used several USB sticks,all formatted with RUFUS,and all working on z10pro,no failed recordings at all.
    In notifications,all recordings were mentioned at correct start time and end time,however the only way to check is to go into mol3 menu>recordings>check recording lenght,to make sure the recording was completed in total.
    Question 1;there is still an unstable scheduled recording present,still not fixed.
    Question 2;what is the use of notifications?
  • Hi
    - EPG: takes some time each day, but eventually loads (don't know how we can schedule as this option is gone in the sync. menu).
    - Can be provider related, but just noticed a few rollbacks of 10-15 seconds. What's your guys experience here, still rollbacks or solved with this Beta?
  • Hi
    Hi
    -EPG on one provider does not load at all in the morning(update in synch set at 05.00 am),other provider loads for max 24 hrs consistently.
    So on one provider i have to update EPG manually,i also do not understand why the datasynch scheduling have changed,besides the fact that they were not working anyhow (meaning autoupdate schedule)
    -As far as rollbacks,i notice them in recordings,but not in live tv!
  • Since the recent beta update i have increasingly noticed a sudden stop of live tv stream ,in several channels,no error comes up the image just shortly freezes whereas the audio goes on.
    Changing channels quickly makes it disappear.
    I am on XC and use VPNnord.
    Anyone else notticed this?Or any suggestions for a fix?
  • I use Internal player and Live Tv is again dropping off and reverting back to Formuler home screen. Even with the new Beta update. It seemed to only work for me just one day. It seems that when I changed channels the process of dropping out of tv stream to home screen happens. I have a formuler Z11 Pro that does not have any issues. Appers to be just thePro Max. I am using the same providers on both boxes.
  • Sometimes,while watching live tv,there is a sudden stop followed by a little blue circle rotating (reloading?),and after 3-5 seconds the stream resumes,no error message comes up.
  • On live tv i notice the audio/video are not synced in MOL3. personally i havent noticed any rollbacks. But the audio not synced is an issue For me in MOL3. On other iptv clients i dont have this issue.
    Are you connected to any soundbar?
    If you have a soundbar connected, please try to disconnect it and connect your Formuler device directly to the TV, and check if the same issue occurs.
    Also, please try accessing 'Home screen > Settings > Device Preferences > Display & Sound > Advanced Sound Settings > Select Formats' and select none.
  • Are you connected to any soundbar?
    Disconnected my tv speaker, same issue.
    Tried changing the setting and also the sound/video is not correctly synced.
    Other apps on the formuler z11 don’t have this issue, it only occurs in live tv on some channels. I tried other clients, and they don’t have this issue with the same provider.
    Edit:
    I noticed it only happens on channels, which have replay capability.
    Edited once, last by burtmachine (November 27, 2023 at 2:24 PM).
  • Disconnected my tv speaker, same issue.
    Edit:
    I have created a conversation with you. Please check the notification.
  • I just went to Homepage and in software in the right upper quandrant i see a red circle with 2 in it,when i press OK nothing happens.
    Did i miss something?
    Edit: i just went to notifications and there is a software update announced,pressing OK ,did start the update!
