audio passthrough settings in MOL3
  • I have factory reset this box multiple times and downloaded auto optimiser app. Changed multiple settings however the Dolby truehd is not on the listed available formats under audio settings on kodi. This leads me to think this box does not support the pass through for this
    Well no, since it works with others... Sorry to insist...
    But I have the z11 Pro Max, maybe the regular Pro is different?
    Could you post some photos like mine with configuration on audio settings in Android settings ans Kodi ?
    Version 21.1 ?
  • I use Kodi v21.0.1 but from APK not marketplace. All audio works flawlessly. Not sure if this helps but this is my Audio settings in Kodi:
    Audio Output device : KODI IEC packer
    # of channels : 2
    Output configuration : best match
    Maintain original volume downmix & stereo upmix : both OFF
    Allow passthrough : ON
    Passthrough output device : AudioTrack IEC, Kodi IEC packer
    All Dolby, DTS, TrueHD,DTS-HD toggles = ON
    I also have Shield and with Kodi (v20) same setup, works fine.
  • Just to add a note on previous issue (lip sync on VOD only). I also have Denon AVR. I found that turning OFF on the TV (Sony) A/V sync settings, will fix the VOD issues but then live tv sync is off. I've tried lots of combinations, including turning Denon audio sync on/off but can't find the right settings. The funny part is that I seem to recall this is was never an issue on earlier Formuler releases (using the latest release). If anyone has VOD and livetv with a denon working for proper lip sync please share.
    I have my Formuler connected to HDMI on Denon, Denon then via eArc (fully enabled) to the TV. Also tried Formuler directly to TV. Thanks all !
  • Hello all.
    May i say something. It worked!!! Many hours of frustration but it works.
    What have i done:
    I deleted kodi and i installed it again. 21.1 play store. I set the settings on the same before. And i dont know what i did different i think only the reinstalation. But it works. Dolby atmos is now displaying om my denon!
    I wanted to sell the formuler because of this, but now it works! I play movies from ssd on Kodi. 7.1 channel :victory_hand:
    Thanks all for the communication here and discuss this problem. If someone needs help i will help.
  • Great to hear you fixed.
  • Hello all,
    I was in conversation with Peter from Formuler and he told me the devs.were working on it, I really hope they will found a solution.
    We all know now that technically it is possible using external player (kodi) so the chipset is able to manage the Dolby true HD Atmos in passthrough mode.
    Now we want it with MOL3 because the internal player is really very good with all options included : resume , favorite,....
    I was also thinking replace my Z11 pro max but now I m waiting about this fix ....:crossed_fingers:
  • SAM  F_Peter
    Any news about this topic ? We are still waiting for a fix since August and even installing the last update from December the Dolby Atmos true HD signal is still not working with MOL 3 ....I m still frustrated that I can read the true HD signals with my Z11 while the Z8 does it correctly 😞
    Do you think it will come with the next update?
    Thanks 🙏
  • Goodday my friend,
    I have a lg tv with dolby atmos sound.
    There is a channel from sky that have dolby atmos. I thought it was "sky main event" channel.
    When there is a game on, i see a popup in the right corner on my lg tv that says "dolby atmos".
    That means it works.
    Edited once, last by Lucky133 (December 12, 2024 at 2:57 PM).
  • Hello
    I tried again today with the latest updates, no problem letting all audio formats pass on Kodi for example, if it is properly configured. With files stored on my NAS.
    DD, DD+, DD+ Atmos, Dolby TrueHD, Dolby TrueHD Atmos, DTS, DTS-HD MA, and DTS-HD HR all work.
    So the hardware is not the issue, it's "just" software.
    On the other hand, I tried with Tivimate on a few files from my provider. It works but only in DD, DD+, and DD+ Atmos.
    The soundtracks that should theoretically come out in Dolby TrueHD come out in DD (the core).
    Just like on MOL3, I believe...
    It's not common to find VOD files in TrueHD (Atmos or not) or in DTS(-HD) on the server I'm using...
  • They will not fix it ... We have reported this issue since almost 1 year and nothing had been done so I m very disappointed about Formuler , no communication at all for a box which cost 160 eur and no HD audio signals supported , it is really not acceptable.
    The only solution is to use Kodi as external player but you are loosing all functionalities from the internal player: resume , history,...
  • Hi,
    Can some please post an idiots guide to getting g passthrough to work on Z11 pro max?
    Goodday my friend,
    Are you looking for this?
    dedelere
    May 17, 2024 at 1:25 PM
    Edited once, last by Lucky133 (April 5, 2025 at 11:21 AM).
  • I've read through the entire thread here, which is all about DD 5.1 and Dolby Atmos, although I find DD 5.1 much better than Dolby Atmos.
    But my problem is that I can't play 5.1 audio from VOD series, for example. Sam wrote to me to install the audio optimizer with a green logo from the Market Store.
    There is no audio optimizer with a green logo. If so, please tell me exactly where I can find this audio optimizer with a green logo. Thank you very much for that.
    My friend,
    On tour formuler is one app called "market app". That app has a green logo.
    If you open market app you will find the app "audio optimizer". That app has a black logo.
    Reason is that we say th market app with green logo is that some people look in google pla store. And not in market app.
  • I'm on the Formula "Market" and it has a green symbol.
    And there's only the simple "Audio Optimizer" app, which has NO green logo.
    And I installed this Audio Optimizer days ago, right after I received the Formula Z11 Pro Max, and there's NO ACC 5.1 sound.
    So, does the note with the "green logo" only refer to the Market app, or something? Then please write it correctly!!!
    It does refer to the market app yes.
    Audi optimizer has black/white logo.
  • yes is here Solved, but ACC 5.1 still doesn't work, which is a shame for a relatively new device.
    As already mentioned, the app "IBO Player Pro" works perfectly on my LG 4K TV with webOS 22.
    I can't confirm the other issue that many users here are complaining about, that DTS or DD 5.1
    supposedly doesn't work; it works perfectly.
  • Last post from Pinarek deleted.
    Pinarek122
    This is last call, one more use of unpleasant words against Formuler or programmers and you will be banned immediately!
    If you don't like the box, return it and demand a refund, we won't allow you to behave here like a fury.
    You were asked by Formuler to explain everything in detail so that it could be passed on to the programmers, but no, you just want to bluster loudly here. Such users can stay away from us! Give normal and detailed info (if you want that something change) when asked or stop to post!
  • Impressive,but not understandable to the average Joe:thumbs_up:
  • Nice piece of work, but for people who doesn't understand.
    In your opinion, on which boxes you need to install and run audio optimizer in in which don't?
    Can you change yourself (you i mean) if you find out something wrong, can you change the .apk audio optimizer for z8, z8, z10, z11 and z12 if needed?
    Audio optimizer is not needed anymore on Z12, because all codecs are integrated! SAM did confirm this earlier after Z12 release.
  • Audio optimizer is not needed anymore on Z12, because all codecs are integrated! SAM did confirm this earlier after Z12 release.
    Belgiumuser,i can confirm that on z12 you dont need to run Audiooptimizer,whereas on z11 (same provider) i do:winking_face:
  • I think you guys are missing afoldal 's point of his post. Yes, you are correct that you don't need to run Audio Optimizer on Z12, BUT he is showing that it does not do anything on the Z10 or Z11 as well.
    On my z12 i do not have to run Audiooptimizer,however on my z10&z11 i do have to run it,if i dont i am left with video and no sound,so it does work,its probably provider related,because in the past i had a provider where i didnt have to run it on neither box:winking_face:
