Hello everyone.
I use a Formuler Z11 Pro Max in combination with an LG television. I also use a Formuler GTV-BT1 Bluetooth remote control. I used the Formuler Remote app to do the “Set up TV IR Control” to set up my LG television and set the Formuler GTV-BT1 to control the volume of the LG television with “Set up Volume Control”.
But when starting up the TV and Formuler Z11 Pro, I have no sound since recently. When I go to the Formuler Remote app and then “Set up Volume Control”, I see that the “Android System Volume” is completely off by itself. If I set it back to maximum, everything works fine again. But why is the Android System Volume all the way down every time I restart? I have been experiencing this recently and have never had this problem before. What can I do about this?
No sound with Formuler GTV-BT1
- Z11 Pro MAX-BT1
- Hardware
moeipindas -
October 27, 2024 at 1:03 PM
Hold ok button on remote app and go to info.
Click on clear data and press ok.
Restart device and open formuler remote again en set it all up again.
If problem stil exist try factory reset.
Clear data and remove The Bluetooth connection from The remote control does’nt work. I Will try factory reset.
Good job.
You did the right thing.
Please let us know if factory reset fixes your problem my friend.
I did not factory reset the box. I downloaded the app “Ziggo Go” last week and apparently it gives problems. I removed the app and the problem is solved.
Great job my friend.
If you use a streamings app like ziggo and you are done with watching.
Always close all backgrounds app.
Push 2x fast on home button and then the red button. Maby it help.
Please reply if you experience the issue again (even after uninstalling the ziggo app).
It's a known issue and normally the developers are working on a fix, right?
Many people here have already reported that when the box comes out of sleep mode, the "mute" function activates.
To avoid this problem, you need to turn off the box instead of putting it in sleep mode.
Or you need to configure one of the shortcut buttons on the remote to turn off the "mute."
This problem is present whether CEC is enabled or not, with the IR remote or the BT1 remote.
Got gtv from beginning and im lucky that i didnt have this problem 🙏🏼
Do you have the Ziggo app installed on your device?
I am also experiencing this issue.
Nope, just classic app (smarttube, mytvonline3)
Check volume at remote app.
check if volume is not to the left.
And it could also be an app.
Did you install last week or 2 weeks some apps?
I added other users picture here, cause he had already made it.
Display More
We know that
Shortcut "mute" works too.
it's a real bug and normaly Formuler working on it...
We know that
Always remove shortcut "mute"
No, this shortcut is really handy for bringing the sound back when the box bugs
Hello I’m experiencing same issue since applying most recent update on z11 pro max.
volume control function is being lost between LG tv and Sonos soundbar. Very intermittent issue seems to work sometimes then other times not.
The GTV-BT1 remote is set IR control is set to LG and Volume control is also set to LG.
When press up and down volume on remote it works intermittently also at times do not get full volume extend from Sonos soundbar.
Any help would be much appreciated. -
Display More
Any help would be much appreciated.Had a girlfriend of mine also.
I say plug power out soundbar en put it later in and is was functional.
Do we know roughly when can expect this issue to be fixed?
We know that
Yeah, reported this issue already in august from my z11 pro max. except shortcut mute does not work for me.
Promised(at pm) this would be fixt with the next firmware update but still waiting..
Please try the new Z11 beta firmware and report your results in this thread:
ThreadOfficial Update - Firmware v. 11.3.5 for Formuler Z11 Series released.
Beta changed to Official Firmware update v.11.3.5. Changelog didn`t change.
BETA Firmware Update for Formuler Z11 Series devices.
Firmware Version : 11.3.5 BETA
WARNING:
If you don`t want to test, please wait until official comes out. No…Z11 Series Update
StaffNovember 27, 2024 at 1:57 AM -
It’s very intermittent, sometimes the volume bar shows on screen but then other times it doesn’t. When up / down volume nothing happens. Need to keep restarting the z11 device for it to resolve itself. I’m more than sure this issue has occurred since the last major update.
Did you install the last Beta Firmware with fix?
Here you see how to.
WARNING:
Sounds like a different issue. The known issue was system volume is zero after waking up from standby.
After a few days with the beta firmware no issues anymore.. 😀
Still have the volume issue where the volume bar doesnt always appear on screen whej adjusting. Its becoming very annoying. TV is an LG and is connected to a Sonos Soundbar. It is an intermittent issue sometimes it works as expected then other times it doesn’t. Can this be investigated please?
Note that the soundbar at the bottom center only appears in the box menus, as it is the volume of the Android system.
Once in MOL3, if you lower or increase the volume, it is the interface of your amplifier (for my part) or soundbar that should appear on the screen, and not the soundbar of the Android system.
Of course I think the soundbar must be connected to the TV's eARC port, and the eARC function must be activated in the TV menus.
