Hotfix Beta MYTVOnline 3 Update - v. 12.1.19 for Formuler Z11 and Z mini released.
  • BETA Software Update for Formuler Z11 Series and Z mini released.
    MYTVOnline 3 Version : 12.1.19 HOTFIX BETA
    WARNING:
    If you don`t want to test, please wait until official comes out. No Forum support in other threads if beta in use, beta issues should be discussed only in this thread.
    HowTo Install:
    The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much longer than usual, please be patient and let the box finish the install. If necessary reboot later once again.
    MYTVOnline 3 v. 12.1.19 Hotfix Beta discussions only in this thread here! Other open threads with Beta issues will be deleted instantly!
    We need to collect data and feedback's on one place, thank you for your understanding.
    Change Log:
    MYTVOnline 3 : 12.1.19 HOTFIX BETA
    • NEW: Added installation guide and QR codes for MYTVOnline+ for iOS
    • IMP: Added "Delete" option in Notifications menu
    • IMP: Move a channel's position by using page up/down in My Groups. (Press CH Up/Down on the remote)
    • IMP: Additional exception handling for "UnrecognizedInputFormatException" error
    • FIX: Unable to play VOD/Series on some portals
    • FIX: Unable to start Cloud Timeshift at the beginning of the event
    • FIX: App abruptly closes shortly after starting the app
  • Gameday gives me a black screen,will try again later,if it remains i will have to reinstall mol3 from Market.
    Is this exclusive to Live TV, or will VOD and TV series have the same functionality? I know we can achieve somewhat similar results with pinned groups, but it would still be very convenient to adjust the unpinned groups without having to pin every single group and reorder them
  • Just got a black screen too on the Game Day. Restart did the trick.
    Just while watching tv black screen on several channels of different providers. Then got kicked out of MOL3, I just sent logs 1735717.
    Here gameday worked fine. When i open gameday i can choose games. So all fine here yet.
    Also no black screen. But i tested one provider. So 3 to go.
    I reply back if i got black screen too.
  • Black sreen gone in Gameday after reinstall mol3
  • Test the beta today. The notifications won't go away, i can click the green button delete all but when i switch from menu or go back to live tv there are the notifications again, the list is still full of all notifications.
    Hi,i have a red and a green button to delete notifications,dont you?
  • Yep just saying when click the green button they are deleted, but when switching menu's or go back to live tv they popup again.
    Maybe you should press both buttons,the green as well as the red?
    Cant remember how i did it ,but notifications were all deleted.
    Huh? You installed yesterday beta right? And did the same thing yesterday i read.
    The beta is same as original update. Do you have 2 z11's my friend?:smiling_face:
    Cause you write the same thing now again? Or did you have the newest z11 mini?😃😃
    Smart solution to uninstall and install it again via market. You fixed your problem. Good job👌🏻😃
  • Huh? You installed yesterday beta right? And did the same thing yesterday i read.
    I did install beta yesterday and Gameday gave "failed to load data",today i got a black screen on GD,so i reinstalled mol3.
    To my surprise,when i checked software update,i was still on 18,so i installed beta again today to 19,now everything working again:grinning_face_with_smiling_eyes:
      I can’t get this to work (Using BT1 remote). Can someone explain in more detail how this is supposed to work?
      Deleting all notifications at once works perfect.
      No other issues discovered so far. 👍
  • I had to reinstall mol3,because Gameday didnt work.
    I then had to use restore function,all favorite channels and VOD were saved,however all my favorite tv-series,but one,were not saved.
    Any explanation for this?
    I have the same, or i dont understand what and how. So please assist
  • I have the same, or i dont understand what and how. So please assist
    In My Groups, you can press the ch/pg button on the remote to quickly move the channel's location to the next page on the list.
    The feature was mentioned by TobbeLino on this post RE: Features Request Z11 and MOL3 (No discussions or questions, only request thread)
  • In My Groups, you can press the ch/pg button on the remote to quickly move the channel's location to the next page on the list.
    Aha, so this relates to Favorites in My Groups….
    I wish/understood that this related to “Reorder Pinned Groups” in the Content Manager menu, Manage Groups submenu, TV Groups / VOD Groups / TV Series Groups…
    The same function should be made available there as well.
    Reordering the pinned groups is a PITA there as well.
  • Timeshift still doesn't work. Talking about direct tv timeshift
    On a channel, i press pause button. Then pressing play doesn't do anything. Rewinding doesn't do anything neither
    You need to have a usb memory stick inserted in order to use that function.
    It works on my box. Z11 Pro Max.
    In the MyTVonlline3 menu, settings, DVR options, Timeshift needs to be toggled ON, Timeshift storage location need to be set to USB Device.
    Works as a charm.
  • You need to have a usb memory stick inserted in order to use that function.
    Works as a charm.
    I (of course) have a usb harddrive connected, recognized and formatted. Timeshift toggle is on. It still does not work
    Hi
    Just got kicked out of MOL3 after startup. Didn't happen so often before this BETA... Sent the logfile again.
  • I install the beta yesterday and i have the same issue:
    - MOL3 start and they kick out again on HOME page.
    - Stanby or power off mode, the box don't want to power ON again!
    - Need to unplug and plug it back to get working again!
    - Do you need the box to make some test ? I think i buy a new **** instead of Formuler!
    - Alls my problemes with this Z11 come after the last update on the box and MOL3... :frowning_face:
    Stay Tune,Return after the EPG LOAD! :smiling_face_with_sunglasses:
    Nvidia...Tivimate...good choice!
  • Could you please provide a video that shows the exact issue for further investigation. You can upload the Image/Video file here: https://streamable.com/ > Upload file > Copy link > Paste the link with your reply.
    Also, please restart your Formuler device, start the MYVTOnline 3 app, and send logs when the issue reoccurs.
    How to Report a problem and Send logs
    Make sure to let me know the tracking number for the logs
  • hi guys,
    A little problem which is a bit annoying: after standby (= red light) and trying to startup, the white lightens up for a few seconds, then there's a little click in the box and the light goes out. Sometimes holding the on/off button for more than 30 seconds restarts the box completely, but most of the times I have to unplug the power and restart (this always works). I've had this a few times before the beta, but now it's really worse and really happens too often.
  • try doing a full reset of your set-top box.
    External Content www.youtube.com
    forum reader
  • I dont think woste will be very eager to do hard reset,as he has multiple providers/favorites,which he will have to redo after a hard reset
    FYI since i started with iptv,i never had to a factory set,on any of my boxes!
