AFR:
I don't think AFR works very well in the Z12 Ultra, I would like to know what settings are recommended. In the Android system's "Device Settings" - "Display and Sound" - "Match content frame rate" I have selected "On".
Inside MOL3 I have selected Automatic Frame Rate (AFR) on TV, VOD and TV Series but I am not satisfied with the AFR result anymore, the picture becomes black for a second when switching from Live TV to VOD and it also takes longer when changing channels.
I run Formuler GTV before I bought the Z12Ultra and AFR works there without problems.
I've only had the Z12 for a couple of days, most things run smooth, but the AFR doesn't work as intended. I have the same settings as Yga, wich should indicate that match frame rate is on, both in the android settings and in the MOL3, but I have to change resolution settings manually. The Z12 doesn't change from 50hz to 23,967hz when content changes, or the other way around, resulting in stutter when content resolution changes. The TV should support it, because the Shield I used until 2 days ago did it flawlessly.
