Connection impossible
Important:
  • Code
    I brought my Formulate to a friend so he could test my new subscription.
    I wanted to connect it in Ethernet, no connection, wifi, no connection ...
    Why… ?
    I check into the settings, Ethernet, i have the IP, but no connection. WIfi, same...
    I connected my smartphone in wifi without problem in his place.
    Back at home, my Formuler connected without any problem.
  • Code
    Why… ?
    the device needs to be able to ping 8.8.8.8
    otherwise it thinks there is no internet connection
    the method to check for internet connectivity will be improved in a future software release.
    the engineers are aware of the current implementation's shortcomings
    Closed the thread.
