As title says, keeps crashing on my z7+.
Open the app, it starts to load my provider but then crashes right at the end with the error "mytvonline has stopped"
Any ideas
Any ideas
Read also this thread, same issue -> MyTVonline not working with new panel
Try to use m3u if you aren't
Avoid using xc, if you are using mac ask your provider to re activate your mac
Since yesterday my tv online keeps crashing after the load bar has finished loading.
The portal supplier has been absent for a week or so, but was told he has now returned.
Maybe everything is buggy, as this has never happened to me before before.
Just trying to work out why it keeps crashing. I have removed and reinstalled the app but it didn’t make a difference.
Any tips guys or have I answered my own question? Cheers
Use link to other thread in my last post over yours and read everything there, then you will know what to do.
Same here... I have two Z7+ and both keep on crashing when trying to open ...
It has to be a problem with the app 'cause other portal addresses open fine.
Yes m8 correct, the M3U portal works ok, so why not the url portal ???
Here is what I got from my provider: "...Your plan was already reset. There is a compatibility issue with the onboard software on those devices and the new system. You will not be able to make it work. We can switch your plan over to Streamline Hosting if you like for use with our android apk's and other third party apps which use m3u playlists.
If there is anything else you need help with Please don't hesitate to contact us. If not you can hit the "Close Ticket" Button below.
Thank you."
So I guess we have to wait for an MOL update...
Hello, blackking
Your provide should be right. Try to test the beta version of MOL. You can check my message in the “black screen” topic:
“Hello, everyone
As SAM said the beta version of MOL2 is available.
In the MOL2 beta version everything works fine and as expected.
I didn’t test yet in the MOL1 beta version (if it is available. It’s suppose be available only at the end of this week).
For the information that I’ve got new versions of MOL are expected to arrived:
- MOL 1 - in the end of this month. In two weeks, maybe;
- MOL 2 - next week.
Thanks to Formuler Support for all the explanation. Excellent service support... and products, of course.”
I can’t use via MAC address with actual release of MOL, but with the beta version it really works normally and as expected.
P.S.: MOL1 beta should be release until the end of this week.
Just had a trial using the url portal on my z7, and it worked, and i think [ don't quote me on it ] his panel was streaminy.... Most trial up to now, including my original subscription didn't work, but this one did....
I'm now able to connect with original ipee supplier using mac id again using formuler z7+
Hi Joana,
please install latest beta for your Z7+ box -> Firmware Version : 2.8.85 or 1.2.85 BETA (Device dependent) - MYTVOnline 1 : 1.9.85 BETA and test again or wait until next week then comes the official fw and sw out.
