What is UTC ?
UTC.
What is UTC ?
UTC.
EPG Mode under Mol2 Menu -> Connections -> your subscription -> Edit -> EPG Mode -> Normal and UTC
Description of UTC posted ddd already ![]()
Set to UTC, do offset if needed, then go to menu and refresh once so the epg loads again, test then.
How do i set to utc? Thanks
Sorry SAM didn't saw your post.
Read posting #42, one over yours.
Bingo thanks it solved my problem.
Hello, my epg dont work after last update , i used m3u url . (z8) , but my formuler nano not update is work perfect
Try the UTC and then offset as suggested in this thread.
in playlist m3u is not option utc
ah, sorry, perhaps try setting it in the "android" "system" settings?
Not have this options UTC in system settings , in anothers programs this epg work !
Hello?
after latest upgrade my VOD movies freezes a lot , is any body else notes the same
Great update!![]()
Hello
When I select Newly added in API Portal> VOD Sort, and turn off the box, vod sort returns to default. Is it possible to correct, so that it remains on the selected choice?
for a box that i Have I do not see the red notification in software update when I've turned the box on .
I have to enter in the software update itself and then it says to start upgrade .
I think it should appear the notification on the home screen because the box was just turned on
It's a rather new feature, so I'd guess that a box with an older firmware version?
Great , I used the resume function flawlessly , keep it up Formuler .
Yes it was a box with old FW so when i turned on the box, the software update should be there a red ballon showing that exists a new FW available
No ! The « new software red notification icon » feature has been added in the first bêta version (released on November 1st). So if your Z8 still have the previous official firmware, it won’t get the notification as this feature disn’t exist in this firmware. It has been added in the new bêta updates.
In the previous firmwares, you had to check yourself in « Software Update » whether there was an update available or not.
What i said is my box as old FW (previous version).That version has [SYSTEM] IMP: Added Software Update notification to home screen widget but it still not showing when i updated to this new version
Hello, 3 things:
1) I have noticed some things during mounting my NAS. I think it is good to share these here:
If I go to Filemanager app, under NFS my NAS is visible as //192.168.1.10:/volume1/movie
If I enter that into my NAS settings in the main menu, I get an error. I must leave out the : and /volume1 part.
so: 192.168.1.10/movie will work fine. It took me some time and frustration to figure that out.
2) A problem is that my movie directory has previous stored recordings and movies in the root and in subdirectories.
The Formuler 8 will add the subdirectory "Recordings" but I when I go to my recordings list am not able to navigate to other directories!!
I can access these in the Filemanager, but I do not want to use two apps to do the same.
Please make it possible that when you view the recording list, you can navigate to subdirectories.
3) How can I tell the system to use VLC as default player?
regards,
Hans
I have a Problem After Last Update with my z8,
I can Watch iptv normaly, but the VOD can‘t load the data So i can‘t Watch anything. On my phone works all without problems.
can anyone help me?
i find in my z8 on update.
Official FW 1.4.54 is 't new firmware ?
It was today's hotfix for people having problems with missing live tv on XC Api. I don`t have such issue and can not test if it works or not.
please fix this serious bugs!!!
EPG DIDNT WORK:
MISSING GROUPS, VOD AND CHANNELS
THIS NOT WORKING
#EXTINF:0 tvg-name="Sobrenatural S02 E11" tvg-logo="http://xxxxx.jpg" tvg-id="" group-title="SERIES",Sobrenatural S02 E11
http://XXXXX.mp4
THIS WORKING
#EXTINF:0 tvg-id="" tvg-name="Sobrenatural S02 E11" tvg-logo="http://xxxxx.jpg" group-title="SERIES",Sobrenatural S02 E11
http://xxxxxxx.mp4
hope you can fix it asap because its really serious
I can't connect to portal after latest update
Display MoreNew official update released for Z8 and MOL 2.
Firmware Version : 1.4.53
MYTVOnline 2 : 7.6.3
WARNING:
Install and use at your own risk. Software cannot be rolled back after installation.If serious errors occur, please do factory reset.
The install process and reboot works automatically! Please don`t turn off the box or unplug the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
Fixes & Improvements:
- ADD: Mount Network Attached Storage (NAS)
- Access from the new home screen widget
- ADD: Launcher notification icons for VPN, USB storage, NAS storage
- IMP: Android Security Patch Level Update: November 2019
- FIX: Temp fix for Disney+ app crash issue on vertical scroll
- Press CH UP/DOWN to scroll up and down inside the app
- FIX: IPv6 ON/OFF bug
- FIX: OK button in Automatic Shutdown menu
- Crash fixes
- Bug fixes and performance enhancements
New Features:
- ADD: VOD Favorites
- Press and hold OK to toggle favorites
- ADD: VOD History
- ADD: VOD Resume playback
- ADD: PiP Swap
- Press and hold RED hotkey to swap.
- Information: PiP is only possible with one sub and two active lines, on XC Api Portal + M3U Playlist. Mac/ID Stalker doesn`t have PiP!
- ADD: API Portal > VOD Sort
- ADD: Refresh contents lists
- Main Menu > Refresh
- ADD: Receive portal messages
- IMP: VOD seek bar
- FIX: Parental PIN gets reset
- FIX: Scheduled recording records a different channel
- FIX: RTP URL playback issue
- FIX: Cannot play certain VOD formats
- FIX: Missing Trailer button in API portal
- FIX: m3u grouping issue with certain list formats
- FIX: Channel group issue after going to previous channel
- FIX: EPG stops working after waking up from Standby mode
- FIX: Cloud TS wrong channel playback issue
- FIX: Crash fixes
Extended Infos:
ADD: Launcher notification icons for VPN, USB storage, NAS storage. Please see picture.
Please read how to -> How to set Z8 and NAS for recording and timeshift over network.
hello.
What are the remote control inputs/commands to operate the functions (if any) of the PIP feature? Or, is PIP on there, stuck in the top right corner in static fashion with no options available?
Thanks in advance.
No time to explore?
Start PiP trough PiP icon.
1. To change the channel of the PIP window, Hold the OK button, then select the channel.
2. For PiP Swap, press and hold Red hotkey.
