Im curious if this Formuler is like an Formuler Z+ (basic model) or like an premium model like the z7+ or z8![]()
Basic model or premium model?
I would say something between
Should replace the old Series z <-> z7+, with lower specs like Z8 but with all benefit of MOL2. -
If I have the Formuler Z8, any advantages/disadavantages to upgrade?!
If everything is working good or very good, and new features in all listings of all the new releases after your current version do not contain anything that you absolutely must have, then don't upgrade. There is always risk that something important to you stops working. And downgrade is not possible.
Not exactly, but if you need other box, want still use MOL2, with less cost and can live with lower specs, then you can buy the new one. Z8 is still the box with highest specs and on first place but Alpha comes on second
I still like the Z7+ with MOL1, one of my first ever boxes that I have bought, from then I was stuck with Formuler. It's still a classic box for me
I agree, Z7+ will always have special place
Hi, i will test the alpha this week-end (I have a Z8) but can i ask you some questions about spec ?
Specs on the Alpha vs Z8 :
8 Gb vs 16 Gb not very important for me
1 Gb Ram vs 2 Gb Ram. In witch case the 2 Gb ram is necessary ?
100 mbit vs Gigabit. A 4k HDR movie will work correctly on 100 Mbits ?
Best regards
Depends how much tasks you open and use other ram hungry apps at same time. In normal situations, IPTV, recording, using 2-3 Apps at same time etc. you will see no problems. In my test i opened 12 tasks + MOL2 with recording, not even one issue
Didn`t tested yet, but should work.
Please report later your view.
Same here. Its for me the best box.
My first was the Formuler z
I have tested the Z Alpha this morning (Connected in Ethernet) and i can recommended it !
A movie 4k HDR from my provider : No problem
A movie 4k HDR from my NAS : No problem
IPTV : No problem
I have notice no difference with my Z8
Best regards
z9 coming out
z9 coming out
What are you trying to say? You could post detailed in future
Edit: There is no z9 and if it come some day, then will this be announced from Formuler and not from someone else. Z Alpha is new Box to fill the place from older boxes z- prime/z7+. Z8 is with higher specs still premium.
z9 coming out
That could be anything... a wish, hope, statement, request, desire or question
Two minds aligned again
I just heard about the alpha today
so say just for iptv the alpha preforms just a good as the z8?
i have a different brand and if i go too fast scrolling it can hick up or freeze a bit with in its apps functions
but the z8 i have never had any issues.
just want to know if i buy another batch and go with the alpha can i expect the same performance at the z8
the extra ram means nothing to me if were just using it for iptv
thanks
Display More
thanks
No difference.
just looking at the alph so it only has 1 usb and no optic audio jack
2 usbs would be better 1 for the hard drive and 1 for the wireless keyboard -
If you insert USB hub, you will have much more
if you have to buy hub you may as well pay the bit extra for Z8 that was the decision i have just made and purchased another Z8
Hi everyone I'm looking for a new device and been.looking at the Z Alpha, do you people on here think.this will be a good box, the 1 Gb is putting me off. Any advice would be welcome
Unfortunately I still didn't get my hands on the Z Alpha, so I haven't had the opportunity to test it, and therefore can't give you much advice, but I think it will not make any difference with the 1GB, of course if you're just planning to use it for IPTV.
You have a complete review on YouTube:
External Content youtu.beContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy. -
There doesn't seem to be many reviews about the Z alpha at the moment
Do you need more reviews than the one i posted ?
Yes as everybody has a different view
well I have been running it for a few days my alpha box and tonight it seamed a bit sluggish like it wanted to think to respond
I didn't find that issue with my z8
is there a way to clear the cache on the alpha other then just a reboot?
Go to android settings and select apps.
Then select mytvonline 2 and clear cache.
Or for all apps at the same time:
Settings, then storage & reset.
Then internal shared storage.
Then cached data.
Good luck my friend
Anymore info on the z alpha
z8 and z alpha have same firmware i thought, so must be the same steps.
Or if you means info like the specs i refer you to formuler website and or google.
my thoughts on the alpha......its a cheaper box and the remote is cheap
spend the extra and get the z8 a much better box and remote
There isn't much difference in price, it seems a bit strange and Price wouldn't be the decider for me. I went for second Z8
