Hello
Is it possible to download a Betaversion of new software versions?
I hope in the new version the frame rate problem is also solved.
Regards Aeffele
Hello
Regards Aeffele
When available yes But same warning It's on your head if you do. No going back
Well currently I would say there is only the way forward. The current software has an extremely large number of bugs. Old errors that have been fixed for a long time on the Z8. (for Example Select a channel 1 directly)
I always do it
Merry Christmas mate
And same to you Happy Xmas
How can we get beta?
No updates yet
What will be the code when beta firmware will be available.
it don't work yet
0227 followed by red button on your remote
it don't work yet
Of course not, because there is no new beta out yet. Beta releases are always announced, after announce you can download and install.
Info: The first beta for GTV is planed for release at January 13.
Thanks Sam you the best
Thanks Sam![]()
Beta out now.
Formuler GTV
MYTVOnline 2 for GTV: 9.2.6 BETA
Install and use at your own risk.
Change Log
Increase Cloud Timeshift compatibility with more servers
Display episode list in ascending order
Add Cloud Timeshift shortcut to Classic channel list
FIX: Can't play recording if system language is not English
FIX: Crash when using certain m3u URL formats
FIX: Grid EPG doesn't load until EPG is scrolled
FIX: Frame rate not displayed sometimes
Bug fixes, optimizations, and performance enhancements
When I try with 0227 and red button (squarepants) nothing happends.
On the Formuler update it says official software but I don’t see any options for try beta.
Cant get the beta myself with 0227
I would wait for Sam to announce it first
Code is 1339
Seems the devs. open already the Beta MOL2 update (planed was 13th).
Please don`t report anything in this thread here until i open Beta thread, thx.
why can't i download the beta version, get to where it says start upgrade press ok but it doesn't happen, it says download cancel, can someone help me, thanks
Download. Then 1339 then press red button. Ok
Hi there,
Go to Formuler Update App, then I enter 1339, press the red button for beta test software, then it says Software Update 1, press Ok, but nothing works, I get an error message and IPTV Download Error
Enter 1339
Press red square button
Press red square button again
Answered and gave you how to do it in conversation.
