Hi
In the settings section there is an option on UI 720p OR UI 1080p
Witch one should I use and what is the actual difference?
Hi
The total number of pixels that make up a 720 p image is about 1 million (that's 1 megapixel in digital still cameras), and a 1080 p image has 2 million pixels. This means that 1080 p images can be displayed in much more detail than 720 p images.
and then Z8 pro works well without any problem with the 1080 p . so adjust the 1080 p
Recommend 720 UI resolution.
UI Resolution only affects the image quality of the menus and on-screen graphics, not the Video playback quality.
Using 1080 UI resolution will slow down your box but the menus might look a little bit sharper.
Is this recommended for all boxes?
Yes.
If you feel the box is slow when it is set to 1080, change it back to 720.
I can't even enter this setting. It crashes every time I want to change display setting. Different TVs cec on and off. Nothing helps
Think about (i know i hate it to) factory reset in that case.
well. after long consideration i finally did factory reset..but somehow it still didnT help.
when i try to go to picture settings it still crashes. any advice?
anything?
Well. It seems it is a bigger problem i thought. I just bought a brand new z8 pro. First thing wanted to check if will be able to change the resolution settings and the same thing happens here. Settings crashes
guess , u have to contact to your reseller.
what does the reseller has to do with it? the first one i saw this happening i ordered from different reseller. today i receive a new one from someone else
Albin, could you please reproduce the issue again and record all steps? Please forward the Video DL link to me in PM. Thank you.
Installed FW and SW is latest?
Yesterday I received a brand new z8 pro. Right after first instalation I have tried to change the resolution and just like in my last z8 pro a window appeared "settings app stopped working". I thought it could be caused by setting up few buttons on remote for the same function when first time I saw this. But yesterday it happened to brand new z8 pro. I already gave it to its owner so can't make a video though
Factory reset and try again. Maybe one of the apps you installed is causing a conflict.
Hello, I am connecting to this topic, it seems to me that the last update is to blame, we have to wait for corrections
hello I have a way for me set the language English (united states)
