New beta for Z8 Pro / Z8 / Z Alpha / Z+ neo and MOL 2 released
Firmware Version : 1.4.78 BETA
MYTVOnline 2 : 7.10.1 BETA
WARNING:
HowTo Install:
Home Menu -> Software Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
Beta FW 1.4.78 - SW 7.10.0 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
Fixes & Improvements:
- NEW: Change system screenshot path. Home > Launcher Settings > Screenshot path
- FIX: Z Alpha Bluetooth issue
- FIX: Crash fix for some OTT apps (SVTPlay, etc.)
- FIX: CEC on/off switch state not saved
- IMP: Updated system time zones
- IMP: NAS mount now visible to other apps
- IMP: Rename "HDMI Auto Adaption" & change behavior to "Auto-select BEST resolution"
- IMP: Block incoming Bluetooth files. Use Android Settings > Security > Allow incoming BT requests: OFF
- IMP: Disconnect and reconnect BT Audio devices without re-pairing
- IMP: Updated remote deployment template
- IMP: CEC: Wake up TV with Formuler. Wake up Formuler with TV (Must use Standby power mode)
- IMP: Memory utilization optimizations
New Features, Fixes & Improvements:
- NEW: Live > Filter only Favorites. Activate from Classic Channel List > Filter (Red hotkey)
- NEW: Recordings > track progress and resume playback
- NEW: VOD Details > Date Added
- NEW: Auto-detect API portal from m3u URL
- FIX: Danish subtitle display issue
- FIX: EPG offset issue with certain services
- FIX: Audio Track Language not displayed for some contents
- FIX: Menu navigation issue for services with no Live TV section
- FIX: Issue with Maximum catchup (replay) days
- FIX: picon display issues
- FIX: Edit Groups > Cannot select certain Groups
- FIX: Online subtitles not displayed immediately after download
- FIX: Player controls do not timeout according to OSD Timeout parameter
- FIX: Episode list scrolling issue on certain portals
- FIX: VOD ends early if paused
- IMP: Opensubtitles > add all languages
- Set preferred languages from Settings > Player Options > Online Subtitles
- IMP: Cursor position automatically moved to last watched index in episode list
- IMP: Improved Skip Ahead performance
- IMP: Scheduled Recordings: Resolve single instance of series conflict
- IMP: Warn before powering off if recording is in progress
- NEW: Menu Translation: Slovenčina
- IMP: Improved Swedish, French Translation (Thanks tvman, GoodGood)
