The Netflix app on the market says it's no longer compatible with the z10 pro max. Does anyone know where to get an apk that works with the z10 pro max?
Netflix app
- Apps
- Z10 Pro Max
latinhawk -
February 11, 2022 at 9:19 PM
Netflix is not supported on Formuler devices.
Thanks. However, the app should be removed from Market, that being the case.
.When I try to start the Netflix app in my Z8, it asks if I should update as there is a new one. If I answer Yes, nothing happens but if I answer no, Netlfix starts and I can run.
Thank you. I followed your suggestion and it worked fine. It even offers to download to watch later.
For others using Netflix. I was having a hard time navigating the app and I downloaded the remote contol setup app and i assigned a hot key with double tap to act as mouse and now i can navigate the app.
I took a gamble and downloaded a netflix.apk and installed it on the z10 pro max and it works perfectly withh all the standard menus.
Bir kumar oynadım ve bir netflix.apk indirdim ve onu z10 pro max'a yükledim ve tüm standart menülerle mükemmel bir şekilde çalışıyor.
hello, what was the image resolution of Netflix in Z10 pro Max with the downloaded apk?
I only pay for hd so I can't tell if it goes up to 4k. However, the image is very good and runs without buffering.
which apk file are you using?
Netflix_v8.17.0 build 2 40144_apkpure.com.apk
This is a mobile version.
Yes it is.
you can use netflix mod apk from https://techbigs.com/netflix.html this app is compatible with your z10 pro max.
Try with a third party apps like 'aptoide' or 'rave'
If he is satisfied with mobile version and it works thats great👍
Look for version 4.16.3 build 15172
It was the last version built for Android boxes (not mobile)
How do you download the netflix apk? I wanted to try it to see if it will work
But why does Formuler not allow it anymore
Netflix is not compatible with android boxes. (Only nvidia box so far i know.
You can try to download
netflix kodi edition apk.
Thats one of 2 versions which work so far.
There is another apk netflix edition were you look netflix in hd.
But that one you can use.with the remote. Use a mouse then.
But that apk i cant find yet
[APP][MOD] Netflix - Kodi Edition (Kodi fork with Netflix) + Netflix Mobile RCU MODNetflix - Kodi Edition is a Kodi 19.4 fork with Netflix addon pre-installed. It's customized for Widevine L1 Android TV boxes and can be installed alongside…forum.xda-developers.com -
issue is not formuler the issue is netflix have to approve formuler(certified)
if you are using the mobile version you will have to enable mouse mode in the formuler remote app.
also installing netflix on a non-aprove device may give less than hd resolution. You will have to test to be sure.
Thanks all for your help Much appreciated
Oh, I've been there with app compatibility issues. It's a bit frustrating when apps stop working on certain devices. Regarding the Netflix app for Z10 Pro Max, have you checked out alternative app stores like Aptoide or APKMirror? Sometimes, they have versions that might work on your device. Just be sure to download from trusted sources! I am getting paid to watch Netflix, so I try to solve the issues with the platform once they approach. I hope that helps!
The boxes are not netflix certified, so no one app works good.
the user tried everything.
And use a netflix app with mouse and keyboard isnt it also.
Use netflix via your tv. (Everyone has this time often a smarttv)
whats about netflix not gonna work starting 4 dec 2023 anyone awhere of this?
Do you have source?
On all marks boxes it dont work. (Exclusive mi boxes, nokia and nvidia) maby more.
Bit not on formuler
Got the same message here
Netflix stopped completely to work on unofficial boxes/old tv's per 4th december?
or
Maby you have shared account or what?
and that the owner stopped it?
Because owner must pay much more now.
Did someone have a picture or source/link for it? Now we are guessing...
Can you be more specific?
Display More
or
Got this message once yesterday after changing episode and I don't have a shared account
so you have a unofficial netflix app on your box.
Maby netflix gonna block it.
I want more info, so i know what it is.
yes, unofficial app on Z10 box, will see in december....
Thanks all
Yes, boxes that are not Netflix-certified will not work, this includes all of Formuler devices.
Therefore, if I want to watch Netflix, then I have to rely on my LG Smart TV to do so.
Otherwise, I would have to use another STB / OTT Box or TV Stick that is Netflix-certified.
When GTV was released 3 years ago, it would have been amazing if Netflix was included among the supported streaming apps.
Other apps that can run well on the GTV include Prime Video, HBO, Spotify, etc.
so far i know netflix works on boxes like: nvidia box, xaomi mi box, Nokia b... the 3 known marks are that.
But Netflix you must use on your tv.
Tv is mostly better than a box.
Also with audio like atmos etc
I currently use LG Smart TV for using video streaming services such as Netflix or Amazon Prime Video.
The streaming boxes that officially work with Netflix are the following:
- Edit Admin:*************
The Netflix app provided on the Formuler Market is considered a "third party" app and was last updated in May 2022.
Meanwhile, when I try search for the official Netflix app on the Google Play Store, it does not list in the search results.For the GTV, the box says it officially supports the following streaming services Prime Video, Disney+, Hulu, Vudu, Showtime, HBO Max, Spotify, YouTube TV, Starz, and Plex. However, I don't use the GTV and now use Z11 Pro Max instead.
So yeah, Formuler can only be used for streaming IPTV services (up to 4K) through the MyTV Online 2/3 app.YouTube and MOL 2/3 are the only ones that can stream officially up to 4K resolution while other streaming apps can stream up to Full HD.
If you want to sideload your favorite streaming apps like Disney+, Netflix or Prime video, then a Smart TV or another streaming box might work. -
Display More
- Nvidia Shield TV
- Xiaomi Mi Box
- Xiaomi Mi TV Stick
- Amazon Fire TV Stick
- Nokia Streaming Box
- Roku Box
- Google Chromecast
- Apple TV
If you want to sideload your favorite streaming apps like Disney+, Netflix or Prime video, then a Smart TV or another streaming box might work.I already now my friend.
It was not my question, but from other person.
Please follow forum rules and do not discuss about other Brands on Formuler forum, don`t want to close this thread too. Thank you!
The link and Netflix site shows exactly what is supported and what not.
Netflix no
Where did you get this message from?
Netflix no
from an unofficial netflix app he said.
Think they gonna block unofficial apps.
