Security update - firmware 10.0.31 and MOL2 10.0.31 for GTV released.
Firmware: 10.0.31
MYTVOnline 2 : 10.0.31
WARNING:
Change Log
Firmware: 10.0.31
- NEW: Update to Android security patch level June 2022
- NEW: Implement Private DNS.
- Access from Android Settings > Network & Internet menu
- IMP: Recent Apps reinstated. Double-tap home key to access
- IMP: Add "Enable USB Audio output" menu.
- Access from Settings > Device Prefs. > Sound > Enable USB Audio output
- IMP: Wake up device using any key on the remote
MYTVOnline 2 for GTV: 10.0.31
- FIX: Stuttering on terrestrial channels
- FIX: Portal connection issue
- FIX: Schedule Recording errors
- FIX: DVB EPG parsing issue
Update:
Please note. The time that the update takes to reach each device may vary. This update will roll out progressively to all GTV devices over the next week.
1. Will be shown directly on home menu.
2. You can manually check for the firmware update from the System update menu, if not shown on home screen: Android Settings > Device Preferences > About > System update
After firmware update:
Open the Formuler Software Update app after firmware update is completed, to upgrade to MYTVOnline2 version 10.0.31 for GTV if not already installed with the firmware. Same with Tuner update to 10.0.32.
