If someone experience roll backs, does he use VPN or without? Please try with VPN and report again. Thank you.
I do not use VPN,-not n esseccary accordig to provider,i did set buffertime to long and AFR on,but dosent make any difference
Some provider don´t allow vpn..
I do not use VPN
Use XCAPI
Rolls backs differ
I had many days without ......yesterday there were two in 3 hours
henkie I only tried recording once resulting in many rolls backs and created a post asking which qualifications a recording device (USB stick, external harddrive needs)
I will do some more tests in the future.
I will also check my settings (AFR and buffering) tonight.
Just my experience since the latest update and more importantly the alternative epg.
So z11pro max, using stalker.
All good on the update, the alternate epg populates as it should so very happy..BUT.. catch up will not work from the alternate epg.... get "cannot play video try later" warning, kind of the whole point of it really? get a message saying cannot play video try later, but later still does not work.
Using the single channel epg the catch up works fine as does vod TV series etc.
So the catch up on alternative epg not working, so changed back to original epg and of course less content showing but the catch up works fine.
Seems we have some way to go just yet with the epg but appreciate the hard work so far
Yesterday one roll back.
AFR was off for TV and movies and on for series (Don't ask me why I did this )
Buffering set to short.
XCAPI
No recording device connected
No VPN
My feeling is that it is provider related
Hi,RZ,why do you think its provider related,as it would be a coincidence that all users who reported rollbacks share the sae Provider?
You are right.
I typed my feeling it is provider related is because lately a lot of things were wrong.
I have been without tv for hours several evenings.
I have been without movies for days.
I have been without EPG for about 3 weeks now.
I have had contact with my provider and these problems were confirmed.
Maybe a lot of providers are struggling with issues at the moment.
Not sure though......hence the gut feelingRhis also makes it very difficult to test the box and it's firmware.
Tonight....
No roll backs
Maybe your Provider(s) suffer from the afterburn of the large raid on a iptv datacenter in the Netherlands,the time frame of your problems certainly suggests this to be the case!
just a question, there will also be a bug fix from you
When the devs. are ready, then will come new update.
thankss
Has there been any update to MOL3 in the past few days as a number of my streams have audio sync issues and are unusable. The provider and others who use the same provider on a different box also say they have no issues but those on the forum who have a Z11 and MOL3 are having the same issue but can't find the cause.
I think in terms of MOL3 everything is working, for me the only thing i feel i need is a way to position the subtitles below video on VOD, vertical offset or something, other than that everything z11 needs is a good android developer to enable all the audio capabilities of this realtek SOC and other features like auto frame rate which needs a bit of adjustment outside MOL3 environment... The devs should at least make an effort for some people to use this box for everything because for now i need nvidia shield + z11 always on and it's summer and i want to save energy. Other than streaming certifications z11 should be able to do everything nvidia shield does and it can't...
Thank you!!
Thanks for the reply, can you recommend an alternative app to MOL3 to test my stalker portal with on the Z11?
Well i can think of a few like tivimate, stbemu, ottnav but you need to pay for it and at the end of the day they all have issues, i feel like MOL3 is the best out of all i've tested. Ofc i never tested buzz tv , premium tv or similar pro iptv apps that come with boxes like mol and formuler, but i assume from what i read here and there that MOL3 and formuler are at the top...
For me, the only thing MOL3 doesn't do are minimal stuff like that vertical offset in subtitles positioning and a system audio decoder that can use the real capabilities of realtek SOC, because this SOC is a strong soc, it should be able to/can decode and transcode every audio codec in real time without issues, but where are the android developers to make use of it?
Display MoreSoftware Update for Formuler Z11 Series devices.
Firmware Version : 11.2.6
MYTVOnline 3 Version : 11.2.14
Important:
Please use backup function first and save MOL3 data on USB stick, before you start with the update.
- FIX: System-wide media playback stutters when certain USB devices are plugged into the device
- FIX: UI display issue in "F1 TV" app
- FIX: Can't re-connect to saved WPA3 WLAN network
- IMP: HDMI stability
- IMP: Hauppauge USB tuner driver optimization
- IMP: Quicker Bluetooth scanning
- NEW: Alternate EPG Mode for Stalker. Access from Portal Edit menu. (MOL3 Menu -> Content Manager -> Content Sources -> Your Stalker Portal -> EPG Mode -> Change from Default to Alternate and set
offset ).- FIX: Can't play some AVI files
- FIX: "MediaCodecVideoDecoderException" error
- FIX: Unexpected cursor movement in VOD menu
- FIX: EPG offset values not working as intended
- FIX: Playback stops when BT audio devices are connected
- FIX: 404 error occurs sometimes when zapping
- FIX: Wrong channel description displayed in Single EPG
- FIX: Can't play certain content with VLC Player
- IMP: Favorite channels disappear sometimes
- IMP: Improved robustness for recording files
- IMP: System screensaver can now activate when media is paused
- IMP: Resume playback not working on some portals
- IMP: Universal Search display improvements
- IMP: Metadata display speed improved
- IMP: Improved Portuguese (Portugal) translation
- Bug fixes, optimizations, and performance enhancements.
This is great news! I recently purchased a Z11 Pro Max. Looking forward for this update.
Good morning I don't know if my problem has already been posted but when I watch live tv I have a rewind of 10 seconds and several times per hour I don't know if it's because of my server or if it's the Z11PRO
This has been mentioned before.
I posted some time ago that I along with others experienced it and the settings I have that has prevented it since.
On any live tv channel, press menu button on your remote and go to settings
Select player options then buffer time
I originally set mine to long but experienced jump back.
I changed it to short and haven’t experienced the issue again.
If yours is set to short, change it to long and see if that works for you
Display MoreCela a déjà été mentionné.
J'ai posté il y a quelque temps que j'en ai fait l'expérience avec d'autres et que les paramètres que j'ai l'ont empêché depuis.
Sur n'importe quelle chaîne de télévision en direct, appuyez sur le bouton de menu de votre télécommande et accédez aux paramètres
Sélectionnez les options du joueur puis le temps de mise en mémoire tampon
J'ai initialement réglé le mien sur un saut en arrière long mais expérimenté.
Je l'ai changé en court et je n'ai plus rencontré le problème.
Si le vôtre est défini sur court, changez-le en long et voyez si cela fonctionne pour vous
Hello, whether we are in long or short buffer the problem is always present.
To all those who have this problem, what country are you from? belgium
THANKS
To all the people who have this problem, what country are you from?
Thank you
Same problem,with long or short bufffer (Netherlands)
I wonder if you are each using a vpn? If so what type & protocol
Interesting to see if there is a pattern.
If using a vpn, does it happen without it?
If not using a vpn at all then it rules that side out
No vpn for me.
I tested the DNS changer. But that didn't change anything.
Hi Thank you for your answer, I have already tried both options but still the same problem. I'm patient I'll wait for my I have a lot of customers who are eager to find a solution
hello the same I have the same concern the 2 options do not work and on the z11 formulate the backtracking is done several times a day and even sometimes 2 to 3 times per hour if not more.
Dear John,
Do you have a USB device plugged in the box ?
I had the same and it disappeared when I removed the USB stick.
Hi could you explain why the usb affects the playing of live tv just took mine out and it not looping back at all ?
Check if Timeshift was on, connect the usb stick with deactivated timeshift and test again? Please report again.
I didn't see an answer so I will answer. I still saw the rollback issue with USB stick inserted but timeshift deactivated. Once I removed the USB completely I didn't see the rollback, like I was previously.
Does same happens also with other stick? Maybe is the current faulty? Just a idea.
I have tried 3 different usb sticks. All the same issue.
Can someone do me a favour if they have the bt voice remote, can you try youtube with the voice search and see if you get a blank screen? Everytime I go to use the voice search my screen goes blank and the only way to get it back on is to restart the box (z11 pro max) if someone could check I would really appreciate it
Working good for me
I have no idea what's gone wrong then lol
If the issue is easily reproducible for you I would like to reach out to you to get additional info so the developers can debug.
Sorry but I will be away from home for about a month on business and vacation. I'll touch base when I am back and can do more testing.
