Is there any chance of the developer's could increase the amount of offset. Under normal EPG guide I need to offset it to +7 but I'm limited to only 6. Why can't we have a 12 hour offset? Would make life easier.
EPG Offset
KoshX -
June 7, 2019 at 4:41 AM -
Will proceed the request to the devs.
Thanks Sam much appreciated.
You are welcome but do me a favour and post the request also in "Features Request" thread. Thx.
I am more interested in why you require such a high offset value in the first place.
What type of connection are you using? (mac, xc api, m3u)?
What EPG mode have you set in the portal options?
If I use normal my offset is 7 hours for all channels. If I use utc it works fine but I get 5 channel that the offset is more than a day off. I know wierd. But if I just had 1 more extra hour to offset I wouldn't be having this conversation. The only reason I said 12 hours it would cover 1/2 day in each direction.
Contact your provider about this. Maybe they can fix it
What dose utc. Mean and has everyone set there’s to it thanks guys
UTC - Universal Time Coordinated. Depends on your provider.
Hi
I have the same problem as the Offset time is only +/- 6hrs and i would need -7hrs to get correct time line on the EPG.
The reason for the need of more then 6hrs are due to that the server that provide IPTV is located in various parts of the world.
It would be a great help to update the Mytvonline 2 app with more options to offset the EPG time, like +/- 12 hrs instead of the existing 6hrs.
Would you think the developer could fix this?
The provider cant change the time as they serving customers all over the world.
Thanks for your time
Tom
I am having the same issue with MyTVOnline (Z7+). I need to use EPG Offset +7h.
Does it help if you do: settings > date/time > disable automatic date/time > set time intentionally wrong but more close to your epg offset?
I have found that manipulating the system time also knocks the EPG times out as well - resulting in the same issue of offset range not being broad enough
HI , I am also -7 , any idea when an update is coming for this?
