New official update released for Z8 / Z Alpha.
Firmware Version : 1.4.60
MYTVOnline 2 : 7.6.10
WARNING:
The install process and reboot works automatically! Please don`t turn off the box or unplug the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
New Features, Fixes & Improvements:
- ADD: Google Assistant & Voice remote compatibility
- ADD: Support for different external physical keyboard layouts (AZERTY)
- Change layout from Android Settings > Keyboard > Layout
- IMP: 5GHz Wireless channel plan improved
- IMP: Enable 24Hz selection from resolution menu (if supported by the TV)
- FIX: Certain apps unable to start from the launcher
New Features:
- ADD: Auto Frame Rate matching
- Turn on AFR from the Settings menu
- ADD: VOD Smart Grouping
- Turn on Smart Grouping from the Settings menu
- ADD: VOD Codec details
- Press Info on the remote during playback
- ADD: Support for teletext subtitles on non-standard pages
- ADD: Support for m3u radio channels
- IMP: EPG > choose if catchup EPG data will be populated in the Grid EPG or not.
- Toggle from the Settings menu
- IMP: VOD > Display more metadata
- IMP: VOD > Empty categories are not shown anymore
- IMP: VOD > History: Delete single history item
- Press and hold OK on a history item to delete it from history
- IMP: VOD > Allow jumping to Live TV during VOD playback by pressing Live TV button on the remote
- IMP: VOD > save subtitle & audio track preference on resume
- IMP: Series > Automatically display same subtitle language in next episode
- IMP: Series > Scroll from first to last episode more easily
- FIX: Series > Previous subtitle displayed in current episode
- FIX: Radio picons not displayed
- Bug fixes and performance enhancements
