Beta Update for GTV and Mytvonline 2 software 9.2.9
  • New beta MOL 2 for GTV released.
    MYTVOnline 2 : 9.2.9 BETA
    WARNING:
    Please keep in mind, this is Beta and could have also bugs or act unstable, it is for testing and not for productive use 24h with your box.
    If you don`t want to test and report, please wait until official comes out. No Forum support in other threads if beta in use, beta issues should be discussed only in this thread.
    HowTo Install:
    Home Menu -> Software Update app -> press "1339" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
    Beta SW 9.2.9 discussions only in this thread here. Other open threads with Beta issues will be deleted instantly!
    New Features, Fixes & Improvements:
    • NEW: Add Search by Actor feature for VOD. Works with compatible services.
      • Click on the Actor's photo under VOD/Series details to initiate the search
    • NEW: Rename custom favorite groups
      • My Groups > Press and hold OK on a created group to access the editor context menu
    • NEW: Add file browser for adding new m3u/xmltv from local filesystem
    • FIX: Device reboots when playing certain contents
    • FIX: Issue when parsing m3u with special characters/encoding
    • FIX: Online subtitle search not working with Greek language
    • FIX: Catchup playback on certain middlewares
    • FIX: Episode playback issue
    • IMP: Automatically fetch EPG data at Normal channel list
    • IMP: Improved Episode display order
    • IMP: Press BACK at 'Resume Playback' prompt to go to previous menu
    • IMP: Improved French Translation
  • It happened on mine today after update. This is what I found out. I switched on box. It was black screen. I turned off. My vpn. And it came on then put my vpn on again. All ok. Then switched box off. Then on. Black screen. Turned off vpn again all came on. So could it be a provider not allowing vpn.
  • Hi,
    The developers are looking into the issue.
    We will let you know when more information is available.
    I think this background of the issue was discovered from words2thewise as per his quote below.
    Whenever the Z8's freeze, the program will eventually come back on. However, with the GTV, this is not the case.
    GTV will stay with this message on the screen and I have to turn over/restart the box to get this message off. Whereas with the Z8, It would automatically solve itself.
  • Feel exactly the same way myself. Coming from a Z8 to a GTV feels like a downgrade at the minute.
    Have had the GTV for 2 months now and there doesn't seem to be any reason or benefit to swapping to a GTV from a Z8.
    Have had countless issues that I have reported here.
    I have had the VPN error were the box is more or less unresponsive if left on with a VPN. To resolve this I have to manually disconnect and reconnect VPN.
    2nd is the InvalidresponcecodeException error I receive. Think I discovered what the issue was when I raised a thread about it here. When the Z8 disconnects from a channel it tries to reconnect to it. However, if the same happens to the GTV, it produces the error "InvalidresponcecodeException". Which causes me to change channels back and forth until the original channel begins working.
    These issues are enough to put people off purchasing a GTV. If I would have known that the GTV wouldv'e had these issues before ahnd, I wouldve kept my Z8 and held off an buying one as my Z8 didn't have any of these issues.
    Very disappointed this update doesn't resolve these issues.
  • I Accidentally deleted my post, silly me haha
    Notes really need to be taken by Formuler because the real issues with this device are not being addressed.
  • I have an issue that I can't keep my manual resolution settings on 1080p-50hz RGB, it keeps switching back to 1080p-60hz YCbCr444 when I turn the box back ON from standby.
    Try to turn off the "Auto switch to best resolution" and try again.
    • Home > Settings > Device Preferences > Display > Screen resolution > Turn off the "Auto switch to best resolution" and try again.
    Check if there is a similar option in the TV settings.
    If it doesn't help, please provide a video and the logs of the issue.
    How to Report a problem and Send logs
    ⚡For your large attachments, Please follow the instructions below(pictures/videos):
    (Click Me) https://streamable.com/ > Upload the Image/Video file > Copy link > Paste the link with your reply.
  • Jennie this is the issue when I turn it On, the gtv changes resolution.
