How to download online subtitles and use this in MOL2.
Please see pictures and follow description inside.
TRIED IT DOESN'T WORK
Where can I find User ID
Doesn’t work even if you allready have a account.
Same for me too.
I get the message:
”Error while signing in. Check username and password or try again later. (-1)”
Even when i try to create a new account.
Manually create a new account on opensubtitles.org website and try again
Change an User ID and E-mail address when you get the error message and try again.
after you signed up the account, please activate the account in your email.
and When you log in, you have to choose <Sign-in> option, not the <Sign-out> option.
works fine for me. Good feature to have, would be good if we could somehow get subtitles for live channels too. I didn't have to sign into subtitle websites. It seems to find it from somewhere.
what I would like to know is how to change the size of the subtitles or position it lower down. Please let me know if anyone knows. Thanks.
How do i search for subs if i want them in danish?, as i see it, it only works for language that Mol2 is translated to.
set mine up today and works great.
Instructions spot on 👍
Works very good. 😊
If you use VPN turn it off and it will work
I use a VPN and mine works fine
Formuler released a software hotfix for your issue today.
Please update the software on your device using the software update app on the Home screen.
works very well🤟
i have 2 account a new and an old none of them work
Excellent. Thank you for this.
Step by step is perfect.
I seem to only get the "error while signing in" message when I don't put in the correct name of the movie.
Sometimes the icon photo of the movie says one name but the text name under it is something else.
Movies get released earlier in other countries than in mine and they go by a different name, so I need to find the real name then search for the CC and all works well.
I don't understand why it does this, but it works for me.
i get 401
where are you seeing the "401" exactly?
which menu?
when i try to download sub i get this sign
401 means Unauthorized. Check if you are logged in or create new account, log in and try again.
This used to work perfectly for me as I am almost deaf and this was a great feature for me.
However since one of the updates it no longer works. I go through everything as before but when I ask it to find the subtitle it
tells me there are no subs available. If I leave MyTVonline and go on the web opensubs shows subtitles which MyTV says there are non.
If I do a factory reset, will this cure the problem?
Thanks.
Could be, but i would create new account on subtitles org and login with new one, to check if with new account your subtitle search works.
Yes I tried that but the result is the same.
Which box are you using?
Will try to reproduce, please give me some subtitle name (exactly what you type in) that you can not find through search but see on the subtitle homepage.
Try the Shetland tv series. If I am able to watch live I can get the subs and if I am out can get the subs on catchup.
If I miss that and try the embeded prog on MyTV and get no subs.
Thanks for your time.
I have had the same issue and have had to clear subtitle cache in the Z8 settings and go on line and log into OpenSubtitles web page and sign in. That seem to work for a few days.
Thanks for your comments but I did try that and also made a second subtitles account but no joy.
opensubtitles.org appears to be recommending opensubtitles.com, maybe this is why the embeded .org in Mytv2 is not functioning.
I have made a new log in for .com but Mytv2 does not recognise it.
Is this a work in progress for an update.
contacted my provider and they said they would notify Formular and maybe corrected on next update.
Just had an update but still the same.
I know not everybody is deaf but subs are a life line.
Problem with opensubtitles servers
https://forum.opensubtitles.org/viewtopic.php?f=1&t=17428&start=45
The sever is back on.
Just so I understand correctly if you activate this it will only work when:
- Watching VOD movies (not live TV?), I don't see the subtitles icon anywhere besides the VOD currently.
- Only shows subtitles if it finds them, I just tried to watch a movie and when trying to turn on subtitles it showed a box to search with the movie name, and then said it couldn't find them.
Correct. For live TV, your provider has to configure the portal to provide the subtitles.
Sounds natural to me.
I got a error while signing in more people have this problem with open subs?
