Express VPN not works on Z11 Pro max
- Z11 Pro MAX
- Apps
Logi -
January 9, 2023 at 7:37 PM -
Change country.
Change country.
i Have try all countries but non works
Try reinstall the app version should be 10.69.0 ,maybe reboot. Express vpn is working fine here.
In vpn settings try split tunneling to add mol3
401 error sounds like provider is blocking vpn geo location. You need to either keep using your isp IP address without vpn if that works or ask your provider to allow every expressvpn IP or choose one country and keep it there...
Sometimes someone with the same provider is probably using the same VPN ip address, it can happen, that's why you should first ask your iptv provider that you don't want restrictions...
Adding a VPN to Formuler and then to Split Tunnel MOL3? That makes sense /ironic off
If Server use VPN by him self or deactivated VPN on Admin Dashboard, (there are server scripts that recognise user VPN`s) connected users with activated VPN will be blocked, no successful connect.. Speak with your Provider...
Sounds to me as if your Provider is blocking Express VPN for whatever reason... Or... Your IPTV Provider too... as SAM already stated, *Ninja´d* 😁🤪
First, I would try to change the DNS Setting within your Router. There are a few good and fast around. I am using Google for a long Time now. It's fast, and I am OK with the DNS...
Second, check if there are any Antivirus is running that is blocking the VPN Settings or any other Security Settings.
If all your tries doesn't work with whatever you did so far, I would recommend changing the VPN Host.I have had very good experiences with ovpn.com. 10 days trial, support reacts very quickly. You can find the rest in the terms and conditions
As long as u get a free trial, try some others to check if it's Express VPN or any other Settings
Edit: Forgot something important... Some VPN providers have problems with IPv6 if they don't support it themselves. You can turn off IPv6 support in Formuler. Try that too
Try changing the server first. Sometimes some servers will not open the stream especially if its stalker connection. Anytime I have a server down I switch to different server if it doesn't work I change to another one and it opens the stream. Am positive this is not formuler issue
The same thing happened to me.
Different vpn and different box, 10PRO MAX,but it happened.
There were no problems before buying the VPN but it started giving this type of error.
Solved by talking to the provider.
Best Regards
Run into the same issue, but with FastestVPN on my Formuler GTV. Solution for me was to download the APK from the website. Perhaps the same will do the trick for ExpressVPN?
Not an ExpressVPN issue. Talk to your TV provider.
Turn on ExpressVPN and try to play a Youtube video. If it plays normally, you know the VPN is working correctly.
oke ga ik proberen vandaag.
Please edit your post and write in English. Read forum rules, only English on this forum allowed! Thank you.
ExpressVPN use to work for me on my Z8 Pro 100% but now is breaks the stream for some reason. I have tried different locations and protocol settings but nothing works. As soon as I change the channel I get a black screen. Sometimes after a few minutes is starts again but then freezes. If I turn OFF the VPN the stream continues. There are days when is works all the time and I can change channels no problem. I even have 3 bars. With the VPN ON I usually see 1 or 2 bars. I don't know if its the provider or the VPN service.
I use Express VPN on Z11 Pro Max and Pro version with no issues.
I have mine set to auto connect on boot (I power off my box in the day and night when not in use)
I also use Protocol UDP Lightway
Have you changed the VPN location to see if that helps?
It happens with other known VPN's like Nord, PIA, etc... It depends on the country IP and protocol used. For me, i find that the best country IP's are the closest to you in terms of "ms". Don't choose more than ~50ms and better to use the faster protocol like openvpn, even knowing wireguard is probably the safest one, problem is those android apps are a crap when implementing wireguard.
The best is using a router with wireguard just for formuler and let it connect to the router without the buggy android vpn apps...
But if it's just to trick your ISP just use openvpn, it's more stable, not fastest in terms of speed because wireguard is the future, but in terms of android, openvpn is more stable...
PS: I used to own a expressvpn account back in the days before the buyout and that auto setting was critical because it changed protocols while connected and the drops i was getting turns out it was caused by the auto setting. Changing it to openvpn udp solved it...
