August update - when?
  • When do you plan release August update?
    What bugfixes and feature improvements are planing to release..?
    Will be implemented feature to instant go from Live stream to recorded content from server with one key press (for example: i watch live stream, press left arow and I want possibility to replay content from recordings 10 or 15 secs before live stream). This is wery need feature on Xtream Codes...
  • there should be an update planned for 22 august ?
    but when i try to update using the update app in configuration i cannot update !??
    i just get a message busy loading and then downloading for 1/10 of a second and disappears
    my current version of my formuler Z7+ is :
    s/w version V.1.2.28
    S/W revision r14371
    buiild date 24 april 2018
    What is the reason i cannot update en what do i need to do to get this update ?
    I need this update for 2 reasons : compressed EPG (.gz) and microSD memory expansion for apps
  • August update
    Firmware Version:
    Fomuler Z/Prime/Plus/Nano : 2.8.22
    Formuler Z7+/Zx : 1.2.34
    FIX: Z7+/Zx Stuck in standby mode
    FIX: Market > Certain apps not showing in custom markets
    FIX: Launcher icons not appearing after reboot
    Added discrete Power ON & Power OFF keycodes
    Custom Android hostname/device name supported. Change from the system menu
    Market shortcut can be deleted from the homescreen
    FIX: Installer Mode > SYSPIN issue
    FIX: Installer Mode > Langauge preset not working
    FIX: Installer Mode > Power mode preference issue
    DRIVER: Add Tenda U12 USB WiFi adapter support
    Android 7 > Android Security Patch Level : April 2018
    General performance enhancements, UI improvements, and bug fixes
    Improved Lithuanian language translation
    MYTVONLINE Version: 1.9.48 (BETA)
    Teletext Subtitles supported
    Manual EPG time offset. Access from the Settings menu
    Xtream-Codes API portals > TV Series section supported
    VOD > Continuous play option added. Press the Green hotkey to toggle
    M3U > All tracks from VOD-only m3u list are parsed and used - regardless of stream file extension
    M3U > Compressed xmltv EPG archives supported (.gz or .zip)
    Automatically hide empty groups/categories
    Added stream codec details. View from the detailed information popup window
    TV Series Shortcut. Press and hold the VOD button on the remote
    Remember last selected subtitle preference per channel
    Improved channel icon caching
    Improved EPG download performance
    FIX: EPG description not displayed when using M3U + XMLTV EPG
    FIX: Black subtitle font when only 1 subtitle track is available
    FIX: RCU VOD hotkey while in Classic Channel list
    https://pastebin.com/QtR86AvU
  • On the recording update part can we add minutes to start/end of epg recordings??
  • gzipped XML file not working for me. I have tried:
    1. xmltv.xml (uncompressed) located on my home network at 192.168.8.1/iptv/xmltv.xml - WORKS.
    2. above file gzipped with 7Zip to xmltv.gz located on my home network at 192.168.8.1/iptv/xmltv.gz - FAILS and MYTVONLINE app crashes on startup (I have to rename file on network to make MYTVONLINE load again to change settings).
    3. Direct URL from xtream-editor pro - FAILS - MYTVONLINE does not crash but I get EPG Download Failed message.
    Maybe it will work when BETA ends?
  • 192.168.8.1/iptv/xmltv.gz
    What method did you use to gzip this file? The filename looks strange.
    Normally:
    Code
    # gzip test.xml
    # ls
    test.xml.gz
    Without the download link you used, it is anyone's guess as to what the issue could be
  • [email protected] I was going to add another provider that only has an M3U for me to use... and they're looooooooooong URLs for both the M3U and EPG... I was glad we could use tinyurl, but apparently not! ;(
    tinyurl is working for m3u + xmltv epg URLs
