Features Request Z8/Z10 and MOL2 (No discussions, only request thread)
A feature I've seen you answer to for quite a while but hasn't yet been implemented is the ability to manually organize your favoritelist. You've said "should be available in a future update" for quite a while now.
.. not to forget the (additional) user configurable favorite lists (now we have only the one list. Pathetic.. )
Record to nas is never going to happen right??
Please make the resume function incorporated in mol 2 . This does not work for me with ms player . Buzz 3000 has it .
record a catchup program will be nice and also save to nas
@All
In this thread please post only Feature Requests for Z8 and MOL2. No discussions or questions in this thread, for discussions please use other threads!
Update smb.
Allow >1GB file transfers via SMB.
Sorry if this has been requested, but could we see if there is a way to build in a Scheduled Restart feature?
ex.. have the Z8 box restart every day or every other day @ a specific time.
I did not test these myself but I assume scheduling the "restart or reboot" command should work with Apps like these...
Check the apkpure.com website for example for these "cron-like" schedulers:
https://apkpure.com/nl/cron-schedu…n.cronscheduler
https://apkpure.com/nl/schedule/ru.kslabs.scheduler
Cron syntax will be explained with this App:
https://apkpure.com/nl/cron-explai…v.cronexplainer
To be able to install apk packages use the apkpure package manager:
Thank you so much ddd I really appreciate it my friend! I know the first one requires root, but will test out the other + see if I can get it working!
Is there a way to create a favourite list of movies and TV shows in the VOD section?
Not yet.
Maybe I am doing something incorrectly, but I could not get the Z8 to reboot with any command I tried to use! Thank you though for the suggestions though! Maybe it will be implemented in one of the updates someday lol
I think you should create a seperate Z8 thread first to continue writing about this.
And then: Which commands did you try and how? Screenshot to clarify perhaps?
Is it possible that MOL2 have skins in the future?? So that user can change the look of the app.....
When using a Portal URL the reminder/recording schedule gets erased when the provider shuffles one or more channels.
I wish MOL2 stores the schedule locally AND warns about removing scheduled reminders/recordings caused by provider changes.
HDMI-CEC option for volume control. Outgoing that is, should enable stock remote to change volume on tv/receiver.
Is it possible to support higher versions than "ministra 5.3"? The biggest iptv provider with 2-4k formuler users don't have support soon... It's a new panel build from scratch (edit versions of xc is edited and not stable...)
Yesss please :)))
Audio volume should be able to be gradually boosted to 200% or 300%.
Add option to record a catchup program.
Add option to record and watch another channel with portal also
Improve netflix app as in smart tvs
Parryperhar edit 1st post with most features so it can be easier to see whats is already suggested and done! -
Working RCU channel numbers 0-9 in grid EPG please
MOL2 channel/stream should not be black in any scenario.
If a channel/stream is not available, MOL2 should display that as a message.
If the loading it taking more (a lot of) time, MOL2 should display that as a message. Preferred would be a % loading indicator.
If it is not known why, but nothing can be displayed, MOL2 should display that as message.
User-friendly, easy and unlimited upgrading and downgrading (switching) between MOL2 versions.
Reason: Many different providers have different MOL2 stability levels in the various (beta) versions.
When going through the EPG you can sometimes see the EPG change from "No information" to program info as the user scrolls through channels.
When it is loading that, there is no "EPG loading" icon displayed.
As a user, when it stays on "No information" you now do not know when it is loading or not.
The EPG loading icon should always be displayed when MOL2 is (re)downloading EPG data in the background?
With series is the highest season is at the top and the lowest season at the bottom, can this be changed if season 1 is at the top? -
With series is the highest season is at the top and the lowest season at the bottom, can this be changed if season 1 is at the top?I think you need to make this request to your provider?
from time to time the picture in mytvo2 disappears for 1 or 2 seconds and returns I tried 3 different lists and always the same ..... often the app also crushes this happens after a new beta upgrade
In TV Series section, being able to mark the seasons and episodes already watched ? Would be great, and easier than opening all the episodes and seeking to the end in order to get the red bar fullfilled
Is there already an option to change the numbers of the channels in the "favorites"?
Are you sure the limit is not set by your provider?
No, I don't know how to change te channels from number? If the channel name as sample is 1. "NPO 1" and 2. "NPO 3" I can't change the number to 1 = "NPO 3" and 2 = "NPO 3" I always need to see which channel is on which number....
I realised just now I completely misred your question. What I read was: Is there already an option to change the number of channels in the "favorites"?
If you have a m3u provider/list you might be interested in this page.
Also, when you are in MOL2 watching a live channel, you can press the green button, a search bar will popup, and then you can do a case-insensitive search for channel names. Meaning, if you search for "npo" (and then press return/enter), you will get all the channels with NPO in the name.
Possibility of marking the saisons as already seen.
Know the number of VOD or Series in the directories (ex: all: 10.000 Films FR: 1500, Films ANG: 3500).
hi all,
i want to suggest two features.
1. possibility to have dual audio output on PiP one the normal output and the other using a bluetooth
2. a reminder when the playlist will be expired, like 3 days before
regards
@All
Sorry if this has been requested, but when in MOTV2, having an option to have the time displayed all the time
Ok i will clarify
When i add a .m3u8 link as a playlist in MyTVOniine2 on my Z8 Formuler it will not play (Its just a black screen) but it will play on VLC on laptop
Put the m3u8 stream link in an m3u playlist. Simple
