Hi Sam
First of all, thanks for the job...
Can we hope for short term fixes for the Z10 ???
Otherwise I replace with the Z8-Pro while waiting for updates to correct the problems ...
Thanks for all
Hi Sam
Thanks for all
Lastest official update...
Box: Z10 Pro Max
My timeshift is set on USB Key (I see it in the parameter)
TimeShift is ON
but PAUSE and PLAY arent available on live TV ... and nothing nothing happen when I push PLAY/PAUSE button
Anyone have that problem?
Fixed...
Formatted with RUFUS into NTFS format
Same here. Z10 pro max. Last beta update
All posted and reproduced bugs was forwarded to Formuler devs. Please be patience until all is fixed and official comes out.
Just got my Z10 pro today and must say I'm pretty impressed running latest beta..
Also for me doesn't work on Z10 pro max even with older firmwares. Usb stick format as ntfs and ex-fat but still doesn't work.
Bug- Show/Hide Quick Settings doesn't work on official update.
You need to reboot the box to take effect.
Is there a fix to stop it going to main menu from standby?
I had fps (flickering, frame skipping) problem on Z10 pro Max boxes, this problem was solved with beta update. but the original software update still hasn't arrived. Z 10 pro Max with a powerful processor, with new updates, Formuler team can offer us a much, much better Z10 pro Max.
I am having a weird issue on the new Hotfix where my channels at times just disappear. Seems more when I switch to VOD then go back to live TV I have to basically clear cache & restart the box for them to reappear. But I’ve also just closed MOL2 and reopened and some channels disappear. Super weird, not sure if anyone else is experiencing this but wanted to bring it up in case. Thanks for the help
On official update Z10 Pro Max connection to provider takes VERY VERY long time, if I compare it to GTV it connects instantly.
I have same problem
I've had a continual audio sync issue on VOD, most of the content is half a second out of sync. If I pause the content and or rewind, it is briefly in sync, then you can see a frame skip after a few seconds and back to being out of sync. I know its not the service provider as the Z Alpha I had before is fine and rest of the setup the same.
Anyone else have this. issue / recommendation for fix?
Same problem. I stopped using Z10. Waiting a fix.
Check PM
Something that had recently been happening as well, connected through XC API, is when I attempt to refresh channels MOL2 closes out. Then after opening back up and clicking refresh again it normally succeeds. Kind of strange, not sure if anyone else has seen this or not but wanted to bring it up. Appreciate the help!
Hi all , I found a new issue and am wondering if more of you have noticed it. It seems like since the .23 update the box comes alive during night time. Didn't have time yet to post it but I noticed it again this morning. I'm certain that tv and AVR were on stand by together with the Z10. Weirdest thing is, it's just the box. I've set the box to go awake and to go to stand by if I press the power button on the remote
I am under the impression that the picture-quality is not as good /sharp with the new official 10.10.25 software.
Somewhat hazy, and some pixelation visible.
Do other users expirience the same issue ?
4k25Hz judder issue seems to be resolved.
i dont see anything different
First impression: picture quality is identical to before. No complaints, clear crisp image.
Switch back from Android main menu to MTVO2 is instant, no delay as I reported before, so that bug is solved.
System settings, Display, Screen Position does not display the wide blue arrows pointing to the 4 TV corner positions like on the Z8. I do not know if this is the normal behavior of the Z10 Pro Max as I do not remember what it was before on the Z10 Pro Max.
New official Hotfix thread is open now -> Hotfix Firmware 10.10.25 and MOL2 Update 10.10.25 for Formuler Z10 Series devices released.
Beta thread closed.
