HI Guys,
Formuler Z7+ not have any issues!
The problem are every time by IPTV Provider!!!
I know what i say!
regards
HI Guys,
I know what i say!
regards
I change to static IP and works lovely.
I don´t understand why formuler don´t say nothing about this.
I hope for a quick fix from Formuler staff.
Cheers
Mike, I changed to (Manual) Static but it doesn't make a difference for me. I have buffering on HD channels and on HD Catchup it is unusable. My connected speed is generally in the range 12-15Mbps.
The same HD channels are working flawlessly on WiFi on TV Mucho for both live and Catchup. Definitely seems to be the Z7+ that has some flaw.
Also the EPG is very slow to load as mentioned elsewhere.
One more reason to Formuler fix the problem.
My connection on HD channels is between of 6Mmps and 8Mbps.
In 4K between of 12Mmps and 20Mbps.
Of course the speed depends on the provider.
I never test my box in Wi-FI Mode.
Cheers
I had open a ticket in Fomuler support, considering the problem of many users have about: "Buffering issues" (The same issue of this topic).
It´s seems the Formuler don´t wanna take responsibility of the Buffering issues on their Z7+ box.
Formuler Support response:
" Buffering issues are a provider/internet issue almost 100% of the time.
What provider URL are you using, and what is the providers website/contact info I will try to replicate your issue.
Sincerely,
Formuler Support "
Guys, i can say that i have another box, a cheap box from a Chinese brand and works very good, without buffering issues problems.
Sincerely,
Mike
Display MoreHi,
Sincerely,
Formuler Support "Guys, i can say that i have another box, a cheap box from a Chinese brand and works very good, without buffering issues problems.
Sincerely,
Mike
buffering issue isn't a box problem. probably the way you setup your box.
Tell me the right way to set up the box?
I don´t see any special configuration to setup this box.
My Formuler is connect to the router and i have 200Mbps download, provider by fiber.
Of course it's related with Formuler!
I've changed to static IP, it does work better. Sometimes when I open some channel it's freezing from the beginning and when I change to other and go back to the same channel, it works fine. It's clearly bug with the device!
As I wrote before, there's no issue when I use a different device with the same IPTV provider on same channels!
I've tested on my TV with Smart IPTV, my laptop with VLC, my phone with couple of Android applications and all of them are working fine.
I've tested on my TV with Smart IPTV, my laptop with VLC, my phone with couple of Android applications and all of them are working fine. SAM
I agree 100%
i have made the same tests has you do and the conclusion are the same!
Formuler related problem.
Cheers
Are you using m3u link or via portal?
I have same problem loding loding this white cirkel loding. And have update to last firmware IPTV app. And i have
100 /100 mbit . I test to turn off z7+ and turn on and works better. But i can't do this evry Day. Turn Off and turn on.something is wrong. So please PM me if i can change anything.
I use mostly by portal, but i have tested with m3u too and the result is the same (Buffering problems)
Just have problems with Formuler Z7+
Cheers
I use portal on My z7+ and i see now evry time i look on any channel it change to diffrent movie i get alot buffring this White cirkel and loding loding cirkel
After new testings, I can tell now by disabling Network connection from the settings and connecting with WiFi, all the channels are working fine and they are even loading faster!
I will inform you if anything changes, but for now this fix may help someone.
I hope the Formuler team will look on the network drivers and test little more, so to fix this problem soon.
EDIT: Unfortunately when I zapping the channels, sometimes it buffers from the beginning and it's impossible to watch, so when I go to other and get back to the same channel, it loads fine.
Even with the newest firmware the issue is not fixed.
The previous 4-5 firmwares were great, such a shame I cannot downgrade.
I've already tried with portal and m3u. It's the same.
I used to have the same issue mentioned here.
After changing DNS to 8.8.8.8 and a static IP, no buffering issues.
I’m not sure if one or another or both fixed the issue but definitely no buffering any more.
So it is not Firmuler issue after all, at least not in my case. 😉
OK, I've switched back with LAN and I've tried with changing the DNS to 8.8.8.8.
The issue with zapping it's still the same like my previous post using MyTVOnline.
"when I zapping the channels, sometimes it buffers from the beginning and it's impossible to watch, so when I go to other and get back to the same channel, it loads fine."
I've already restarted the MyTvOnline app.
but, I've tested with STB Emu, Perfect Player and it doesn't have a single freeze at all!
Have you tried a static IP?
Hi eveerybody,
I have an issue while watching VOD 4K : everything runs smoothly during the first 30-45 minutes, then the buffering starts (frequency +/- 3 minutes)...
When I reboot the router or quit MytVonline and go back to the movie, it runs smoothly a few minutes and then buffering starts again.
Using a VPN or not , does not change anything.
My Z7+ is wired (Wifi is even worther), Static IP outside DHCP range. DNS switched to 8.8.8.8. Connection speed : 92 Mbps down .
Could a direct PPPOE connection help ?
Thank you for your help
Yes, of course.
Display MoreHi eveerybody,
My advise, open a ticket on https://support.formuler.tv/new
Formuler have to assume her responsibility.
Cheers
Guys,
Don't forget that buffering issues could also be what's between the streaming server and your isp. If there's a system having routing problems, network issues, or possible throttling along the way.
My setup is very simple. 50mbps, yes.. only 50mbps with 2 z7+ wired, 2 ipad and 2 iphone. No buffering issues.
I could run 5 streams at the same time with no issues and I'm with Spectrum Cable (Time Warner Cable)
One thing I have noticed, is that the Z7+ become hot (very hot) when the buffering starts. Could it be this be the explanation ? Critical temperature is reached...
To Rickiev : I understand your point of view, but what I can not explain, it works fine for 45 minutes, then bufferings starts (also frequency of buffering increases). I have this issue only with some 4k VOD streaming (not all...), no issue with FHD or normal streaming.
Kind regards
Chocolate
Evening
I am now nearly certain that the buffering has nothing to do with the box or how it is set up and all to do with mytv app.
I have three providers linked to the mytv app today it has buffered like crazy to the point where all of them were unwatchable.
I decided to install the providers own apps and I haven’t had a single buffer with them.
Any idea what the optimum settings are for the mytvonline app?
Evening
Do you have a box from other brand, to test your three providers?
Cheers
Evening
That's odd. I have three provider as well, plus one using the mac address. No issues. The mac is a static ip assigned by my router. M3U links with the other providers. No issues with buffering. My speed is only 50 mbps, nothing major and works perfectly.
As Rickiev, I experience no or very little buffering issues. The only setting I changed in MOL is I put the buffering time at the lowest. Otherwise, all plug and play. Plus a really good IPTV provider. He offers me the option to change sources for the stream if I do experience buffering. In 99% of the time, this solves any issue in those few cases there is an issue. If things cannot be solved, its almost always an issue with the source of the stream. This can even be streaming the wrong content. Changing sources solves this issue as well in most cases.
But don't forget: this is IPTV. If you want a perfect service 100% of the time, this is not for you. There always will be issues.
Guys,
When I go to VOD and watch movie it buffers a lot.
The same provider on the same connection using Smart IPTV doesn't buffer.
Is this a known issue of MYTVOnline?
I have been testing this product for about a week now and all I can say that it works perfect !
No buffer on 4K VOD movies, no buffer on IPTV channels.
I recommend it to everyone who has problems with buffering:
It´s supposed we have problems with Ethernet connector of the Formuler Z7+ (10/100Mbps), to buy a USB external RJ45 gigabit adapter?
No make any sense in my opinion.
Happy new Year
Cheers
i did have buffer issues when i first had my z7+ ther only thing i did and has worked is changed to static ip address in settings and rebooted device. fingers crossed since then no buffer but i do have a really good iptv provider so that could of helped as well
Não consigo por o meu epg a funcionar como posso fazer?
Ola andre
o epg funciona 100% na formuler na mytvpnline app!
a ondes estas a usar??
I tested my formuler Z7+ with a external USB 3.0 Ethernet adapter and the buffering problems are the same! a lot of buffering.
Tested with https://www.tp-link.com/us/products/de…3_TL-UE300.html
I gave up and purchased something else since two weeks. It doesn't have any buffering and it's a real beast.
I won't mention the name of the other device, 'cos I don't wanna brake any forum rule.
Bye, bye, Formuler it was a great journey, even tough it was short.
Hi:Also with buffer problems on a Z7+ i am going to explain here my net work and i just order a Z8 to see where this go.
I am in portugal with fiber 1Gb/ 300Mb router with internal network at 10Gb an 1Gb, router is capable of 8 to 10 Gb of routing at the moment, I am a Network admin for big networks. What i have done:
1- going to manual ip not dhcp ( android 7 problem when it sleeps after wake it stays on 10Mbit)
2 - use a usb ue300 with a Gbit ethernet port ( burst of network goes from 60 Mbits max to 130 Mbits) it improves fast loading on mytvonline
3 -tested network speed with iperf3 on internal net 600-700 Mbits tcp ( the server side is at 10Gb)
So its NOT network (speed test for outside PT gives 930Mbit down 280Mbit up) 4ms in pt, 38ms to 40ms for france my iptv provider
Next week i will post results with Z8 and MytvOnline 2 (software)
I am going to solve this anyway the hammer is ready ![]()
Ernesto, if u can't solve the problem,please lend me the hammer😉
Display MoreHi:Also with buffer problems on a Z7+ i am going to explain here my net work and i just order a Z8 to see where this go.
great news friend.
I like to follow from now on your posts.
Great network do you have btw👍🏻
ive had the z7+ since it came on the market.i changed to static ip rebooted router and device,bingo no buffer at all.a lot of isps can detect sertain devices and throttle internet try using a vpn like express vpn see if that makes any difference.i no for sure isp will throttle e2 devices {zgemma} another consideration is to do with providers servers,were there located
ive had the z7+ since it came on the market.i changed to static ip rebooted router and device,bingo no buffer at all.a lot of isps can detect sertain devices and throttle internet try using a vpn like express vpn see if that makes any difference.i no for sure isp will throttle e2 devices {zgemma} another consideration is to do with providers servers,were here located
Hi: thanks but that is not the case i have a server in france where i can login wiht sstp vpn or pptp vpn and my router is capble of 2.5Gb 256 tunnels with AES-256-CBC + SHA256 so they con not throttle anything as i can do bandwith test with the server in france inside the vpn and i get always 98 Mbits
the network is limited at 100Mb no trafic limit, and i can check if there was throttle i could sense it more to do throttle on https (sstp vpn) most isp do not do that because of complains of clients.
Hi everybody:
The Z8 has arrived it is android 7 (expecting 8 i do not know why!!).
It is fast, still looking menu stuff
