Android 10 Upgrade for FORMULER GTV
  • another issue I'm facing after update when I refresh vod sub nothing updates I have to disconnect from portal and renter for new content added to show
    Please provide the information below to assist you better
    • Did you update from GTV Android 9 to GTV 10 directly?
    • Was it working normally before the update?
    • Let me know the connection type(MAC/XC-API/M3U)
    • Try to test another IPTV app and let me know the result
    • Ask your IPTV service provider if there is a known issue with it
    • Provide the logs of the issue: How to Report a problem and Send logs
    Thanks,
  • Occasionally after a wake-up (from standby) I get a black screen. EPG can be displayed but EPG updates are extremely slow (if any). Change of channel does not do anything, still a black screen.
    Restart of MOL2 makes the current channel to be displayed, but EPG updates are still sluggish as is channel change (several seconds before any reaction when changing channel).
    A reboot of the device solves the problem.
    I will send you a private message with more instructions.
  • Hi,
    Thanks,
    Many thanks will do
  • Hi,
    I observe recording errors with the GTV on the NAS, whether with Mol2 or with Tivimate.
    The recordings almost always stop before the end, sometimes they go to the end but it's rare.
    Conversely, with my Z8, it worked every time.Of course I reproduced the same tutorial for the GTV with only a change of ip address.
    I had read that there were some problems with the NAS with this update: is it really that and if so, do we have an idea of its resolution?
    If not, then I confess I'm confused...
    :thinking_face:
    GTV
  • Are your recordings unattended? Or do you sit in front of the TV when you make the recordings?
  • Are there any plans to issue a new update? Seems like this update has affected everyone in some way.
    I don't want to reset the box as it means all my settings and favourites are also lost since there is no backup function. Any plans at all to fix this Formuler? Great things were promised with this update. Instead barely anything to shout about was released, and made the system more buggy. How is that fair for your users?
  • after the update I have had some problems with the buffer I already did the test with a formuler z7 connected at the same time as the gtv connected to the same net by cable same provider but on different televisions of course on the same channel and sometimes on gtv the channel starts starts and even brakes on the box formuler z7 without problems always fluid. this gtv box cost so much money and is getting a big disappointment
  • Hello,
    Thanks for the update.
    The image quality seems to be better than before in general, but horizontal stripes still suddenly appear on images with large solid areas (it occurs more on FHD channels, than HD ones, with screen resolution 4K 60hz or 4K 50hz ; it never occurred with the Formuler Z8).
    Another strange problem : the scandisk key USB.3 256 go I used with a Formuler Z8 is not recognized although it has been formatted. I must use an old USB.2 key for timeshift.
  • Continuation of the tests:
    Yesterday, I scheduled a recording and put the gtv on standby; I saw the box turn on a few minutes before the start and it went back to standby without recording...
    I turned it back on and made an immediate recording: a few hours later, I noticed that it was still on (normal) but that the recording had only lasted a few minutes instead of 2 hours.
    I checked the permissions of my NAS and everything seems to be in order...
    I don't understand what's going on..
    GTV
    Android Settings > Device Preferences > Power Key Behavior > Verify mode is set to Sleep (Standby)
    Open MOL2, schedule a recording to start 10 minutes from now:
    1. Open the grid EPG view by pressing the EPG button on the remote
    2. Navigate to a future event
    3. Press OK on the remote.Do not press the RECORD button.
    4. Manually adjust the Start Time parameter to be +10mins from now
    5. Press SAVE
    6. Exit from all menus and from the app
    7. Press the power button on the remote
    8. Wait 10 minutes in front of the TV to see what the GTV does at the scheduled recording time
    9. Report back with your results
  • Hello,
    Make sure that your external hard drive is formatted as removable storage on GTV.
    If not, please follow the instruction below to see if it helps.
    • Home > Settings > Device Preferences > Storage > Device storage > choose the external hard drive > Erase&format as removable storage > try to set the timeshift location
    Thanks,
    I sent you a direct message. please check our conversation to assist you better.
  • Make sure that your external hard drive is formatted as removable storage on GTV.
    Thanks,
    I simply don’t know what to do. I « ejected » both my USB keys (USB.3 and USB.2). As a result : they can’t be used anymore. The GTV considers that USB.3 has been « safely ejected » and doesn’t allow to do anything (I’ve formatted it again with my PC before inserting it in the GTV without any success). USB.2 is recognized but is not considered as « connected ». A nightmare.
    Edited once, last by MajorTom (July 15, 2021 at 11:49 PM).
  • Hello, I posted a message before in this thread because I was stuck in the gtv boot screen after the update.
    I've received a new box.
    I plugged it in and it immediately started downloading the v10 update. Half way through the installation the screen went black and the box rebooted. Again I'm in the gtv black boot screen. I'veet it sit for at least 6 hours and its stuck again! I've tried the toothpick method but this box doesn't have the button inside the ir receiver? I've looked for it for 2 hours, but it simply isn't there? I have the z8 for 2 years now and never had a problem. I'm getting the feeling I've bought an inferior product!
    Hi, can you let me know what TV brand you're using?
    also, please try to test the GTV with another TV or monitor to see if the GTV is working or not
  • I simply don’t know what to do. I « ejected » both my USB keys (USB.3 and USB.2). As a result : they can’t be used anymore. The GTV considers that USB.3 has been « safely ejected » and doesn’t allow to do anything (I’ve formatted it again with my PC before inserting it in the GTV without any success). USB.2 is recognized but is not considered as « connected ». A nightmare.
    please try the instruction I suggested and provide a video of the issue to assist you better
    ⚡For your large attachments, Please follow the instructions below(pictures/videos):
    (Click Me) https://streamable.com/ > Upload the Image/Video file > Copy link > Paste the link with your reply.
  • Wtf it worked 😁?! Ive connected it to my monitor and its starting the system update? I'm glad but Do I have to do that after each update?
    Ps. I also have an seagate external 3.0 HDD and wireless Logitech keyboard connected when I updated... Could that have had any influence? Just giving as much info from my end to pin point the bug
    Edited 3 times, last by RiZK (July 16, 2021 at 12:53 PM).
  • I'm glad but Do I have to do that after each update?
    No.
    Is possible. Trough such big OS upgrades and major updates it is best to disconnect all 3th devices from the box and do then the update.
  • No.
    Well I finally had time to connect it to my TV again and guess what? Stuck in the loading screen. Do you have any suggestions why I didn't have any problems with v9 and I simply can't get it to boot on v10? The Philips TV is a new model. I didn't have any devices connected to the GTV now. It works on my monitor but not on my TV. I also have a z8 and that one works perfectly.
  • You mean the GTV works always fine and boot each time on Monitor, but not on your new Philips TV?
    Yep that WAS the case. But I fixed it an can reproduce the problem now. If you set HDMI Ultra HD to "optimized" it doesn't boot. If you put it on "standard" it wil go through the boot sequence. Maybe it has something to do with v10 and how it displays uhd/hdr content. I also own a shield that's also on v10 and it doesn't have the same problem. Hope I can help you and others with this info.
    Edited once, last by RiZK (July 19, 2021 at 9:47 AM).
  • Yep that WAS the case. But I fixed it an can reproduce the problem now. If you set HDMI Ultra HD to "optimized" it doesn't boot. If you put it on "standard" it wil go through the boot sequence. Maybe it has something to do with v10 and how it displays uhd/hdr content. I also own a shield that's also on v10 and it doesn't have the same problem. Hope I can help you and others with this info.
    Thanks for the information.
    I'll deliver it to the developers.
  • I have been having a problem with my GTV for days. When I connect to Mtvonline2 it doesn't take long and the channel I watch starts to make black screens. Sometimes it returns to the broadcast I am watching but sometimes the black screen stays fixed on all channels. The only solution I have to watch Iptv again is to disconnect and reconnect or turn off the GTV and turn it on again. To all this I must add that sometimes the image remains fixed in a channel and when I try to tune another one nothing comes out. I have the latest GTV update installed. Everything started after that installation. What should I do?
