formuler z8 remote control functions:
where to find a manual, picture or something similar? Thanks
Best to play around and be curious to figure out what the buttons are for. I seem to remember a bit of a manual/picture awhile back but can't find it
Fantastic. Thanks so much for your help 👍
Is there a description how to add my TV to the remote control 'TV on/ofe' button?
There is a description on the back of your formuler remote control.
Worked. Thanks
Anybody knows how to reset the remote to default? All my buttons when pressed the stb light comes in. All buttons except the pause button. When I press the pause button,the stb light does not come on.
Check and see if your buttons aren't stuck. Otherwise get a new one.
Thanks, i just had to press a little harder for the button to work. thanks again/
Hi I have brought brand new z7+ and the remote control is not working changed battery nothing trying to press tv button on remote and holding it and the light is not flickering
check if your battery isn't dead
Is there a method to toggle the onscreen keyboard on and off like the cursor?
suppose no answer means it is not possible
On appears when you need to do some input and off with exit button.
Thanks Sam. I'll try.
Does new ir remote light up?
I think no (unfortunately)
If you mean the vertical led: With each button press, the led flash.
If you mean backlight: No, is not available.
This may not be related but any assistance would be appreciated.
I was happy using the directional keys to navigate the menu’s then a mouse cursor appeared on screen. I would like to switch off this mouse cursor and revert to the directional keys as I find them far less frustrating and easier . Any ideas on how to switch the mouse cursor off ?
