Beta firmware 1.4.20 / Mytvonline 2 software 7.2.0 for Z8.
  • Hello,
    After the beta update, it's all about EPG LOADING.
    Another problem is that I have to reset the box every time if it was not used overnight because it has no internet anymore although it is connected in the settings. Whether that has to do with the update, I can not say exactly.
    I am connected via portal.
    Edited once, last by Tomek32 (July 3, 2019 at 12:35 AM).
  • For those of you complaining about the "EPG Loading" icon staying on the screen, please tell us how long it is on the screen for.
    Does it stay on the screen longer than 1 minute? 10 minutes? forever?
    If it stays on the screen forever, it could be a bug. After all, this is beta software and some bugs are to be expected.
    Hours! I´ve not seen it dissapear even after watching tv for some hours. Im running via portal.
  • I also have the EPG Loading permanently up there, Restart did not succeed
    Then I always have the problem that over Xtream Editor "series" only the first 10 are displayed, according to Xtream Editor, this is a MOL Bug?
    I put the series there on "Movies" I see all.
  • Hours! I´ve not seen it dissapear even after watching tv for some hours. Im running via portal.
    The developers are looking into the issue now.
    In the meantime, can you please try the following steps to see if it helps?
    MOL2 > Settings > Clear EPG cache
    Android Settings > Apps > MOL2 > Clear data/cache
  • Detalhes boa tarde tenho uma box formuler z nano e tem PIN e e n sei o link para fazer restauro do sistema, como o pesso fazer?? Para meter nova lista preciso do pin, n me deixa fazer nada assim
  • Hi guys...
    I’ve had a look at other post however can’t see anything that matches my issue. Sorry if I’ve missed something and duplicated something.
    My issue is since the latest update (beta version) I’ve had buffering issues. When I press the info button the signal bar only shows between 1-2 blocks..before it was always full.
    When I change channel it changes straight away however after a couple of seconds I get the loading wheel and then connects. I’ve resorted to going into mytvonline and changing the buffering time to 7 seconds.
    If got fairly adequate download speed that averages out at around 35meg so should be more than enough to run as it did.
    Any help would be appreciated 👍🏻
    Sorry forgot to had I’m on the Z8 😊
  • Hello
    1. Timeshift Access from Live TV > Info Bar toolbar is not enable with xc api, can you make it accessible please?
    2. the function research in vod with "add time and alphabetical is not enable too with xc api
    3. Will actors' pictures be available someday? With xc api?
    Thanks for answers
  • Hi,
    Not sure if this is only on the beta or previous versions too, but I’m using beta so I’ll ask here...
    When in MOL2 and press info, then settings, what is “jump interval”? What does it mean and what does it do?
    It configures forward/reverse skip time. I have mine set to 30 secs just like my old cable box.
  • i would like that you implement this on next version:
    -Edit portal name.
    -When we write portal link we should see a legend on bottom with the hotkeys like back button to close keyboard ( i take sometime to find it!!
    -And also on z7+ we have the channel logo and another small logo wich is the provider logo and on z8 we dont have that logo.
    See image attached and is the small logo just above the channel logo
    - Catch up by program instead of time, like we go to the epg timeline click to enter the program and then it show a box with the days back and time that this program was showed on tv i think this is not possible now.
    For now i think we have to go to the epg timeline and goback days and days
    - Mark with icone VOD episodes already viewed i think this is ok on z7+ but not in z8(not implemented)
    Also on z8 we could see 2 xhannels like recording one channel and see other but i dont know if it is by connecting to other portal or just changing the channel
    Standby could shows the orange ligth instead of red , red should be only on Shutdown , so at least we could notice some different when looking to the box
  • Hi, have the Mol2 dosnt work since a few days by me. When i start it i dont have apicture or sound only i have EPG data but all other things i cant see or hear😥. Please some helps me i love my Z8 and now this. I used the Beta to finish my Problen but it was useless...
  • Jeru79
    Please continue to post in other thread, your issue have nothing to do with this beta. I want to help you, so please answer in other thread and follow my questions or answers.
  • Same here.
    These types of "me too" responses are not productive.
    This is not a thread for simple complaining. This thread is meant to be a focus group for individuals interested in testing and helping debug the BETA software before the official software is released.
    If you encounter an issue with the BETA software and you think it is a bug, please provide as many details as possible about the issue.
    Helpful information:
    • Any error messages shown on the screen?
    • What did you press just before the crash?
    • Is the problem easily reproducible?
    • USB storage type: flash, HDD, other?
    • USB storage filesystem: ext4 or FAT32?
    • USB storage capacity: Total vs. Available space
    • Expected backup file size as reported in the backup app
  • With this beta, is it possible to sort the vod view from tiles to the list view.
    One issue I have noticed is that when I search for a series from a list, it comes back with no results. but a manual search will bring up the series.
    Also Adding Series to Favorites I can't seem to find.
  • Back to bluetooth. Yes my Beats headphones connect up and work fine but tried to connect bluetooth to my MacBook Pro, iPad 6th generation and my iPhone 7 Plus with no luck. I just also tried a Windows 10 PC an Lenovo Laptop and no luck either. Tried removing headphones but no luck.
    I was able to pair up my Beats Headphones after trying all the other devices. Think the Bluetooth routines need a bit more work. Thanks for working on things. Love the support.
  • Hello, I have a problem with the replay since the installation of the last beta, I have each time the video that runs in a loop. Otherwise, the live and the time shift works perfectly.
    I use the connection by the mac address
    Please make a video of the looping issue and attach it to a new ticket at https://support.formuler.tv
  • I think its a bug! It still forever and not all epg are loaded!
    I have the same bug, I'm on the latest bets. The EPG Load is persistent and does not go away. The EPG also shows up just fine. In my case I can confirm that the EPG loading is there all the time. Even if I'm watching the TV for 4 hours, the sign still shows up.
  • I have the same bug, I'm on the latest bets. The EPG Load is persistent and does not go away. The EPG also shows up just fine. In my case I can confirm that the EPG loading is there all the time. Even if I'm watching the TV for 4 hours, the sign still shows up.
    Known issue.
  • Firmware Version : 1.4.21 BETA
    MYTVOnline 2 : 7.2.1 BETA
    Change Log inclusive of previous Beta release
    New Features
    [MOL2] XC API > Cloud Timeshift
    Fixes & Improvements
    [MOL2] FIX: Vertical scrolling bug in grid EPG
    [MOL2] FIX: No video on certain live streams
    [MOL2] FIX: Unable to play certain static VOD contents from Live channel list
    [MOL2] FIX: M3u channel name regression
    [MOL2] FIX: "EPG Loading" doesn't disappear from OSD
    [MOL2] FIX: Channel index issue on XE portals
    [MOL2] FIX: Stream looping issue (experimental)
    [MOL2] FIX: Live channels don't play after pressing CH UP button rapidly in succession
    Various bug fixes & optimizations
  • „Streaming looping issues“ (experimental)
    Even tho I’ve received a mail that I should install the Beta and try it out since I’ve the looping issue. I read here that few of them have the same problem.
    If someone can report, after the beta installation if this problem still exists or it’s been”fixed” or minimized it would be very appreciated!
    I don’t have nothing against the Beta but reading the comments makes me bit worry :smiling_face:
  • I don’t have nothing against the Beta but reading the comments makes me bit worry
    Installed today, works very nice. I don`t have your issue with loop and it is in your interest to test in time, so the second beta can still be improved if problem exist. After closing Beta, it`s done and official comes, then is to late for fix in this update.
  • Installed today, works very nice. I don`t have your issue with loop and it is in your interest to test in time, so the second beta can still be improved if problem exist. After closing Beta, it`s done and official comes, then is to late for fix in this update.
    Sound good Sam, thnx for the Info! I think I’ll give it a try with the beta now!!
