Copy and paste into the sources fields is not possible. Would make it easier if that would work. Thanks
It does work but dont hold instead double tap regards.
The app is amazing and thank you sooo much for showing the Apple love. Any chance you’ll make a TVos version of this app? I would pay good money for a lifetime membership and or a solid month to month if this is in the cards.
That defies the logic of buying their boxes. This is for phones and tablets to hook you into buying the box. Which you should. If you are into spending that much on Apple TV get a Z11 Pro Max.
I understand that this would take away from the boxes but would generate a new source of income with limited capabilities and provide the consumer more options. No harm with choices and some folks like myself have multiple platforms and tend to gravitate to an easy to use ecosystem. I’m great with complex setups and programming things but other folks that attempt to use my setup hate it. If this formular box had Dolby vision and atmos followed by being a certified Netflix device. This would be no brainer shield destroyer.
It would be fantastic if VOD and Series could be sorted by rating.
I installed it on the ipad - I have the same problem as the previous Android one - live TV is ok, Films ok - series do not work. Failed to load VOD data? Apple and Android.
Any suggestions ?
Looks like a provider side problem.
At others it works well.
At your side on both apps not. Do series work on your formuler box or dont they?
Best iptv app I’ve used on my iPhone. And it’s free. Mental
Hi now it’s available for iOS is there a way to rotate the screen so I can view content in landscape mode please? I’d like to view full screen landscape, thank you in advance
On my iPad Pro rotate works perfectly. Can view everything in landscape mode. The only downside is as posted earlier that the menu is only availlable in portrait mode…
Is there no way to export your settings like there is for Android so that all the portal settings just transferred to your iOS
The QR code option isn't there like the android version
The QR scanner will be included in the future update.
Is this the next update? Do we have an ETA for this?
THANKS FOR GETTING THIS ONTO IOS GUYS...
No Eta and yes it will come with next update.
All requests forwarded to Formuler.
Thank you for the iOS version! Are there plans for an Apple tvOS version as well?
Haha people asked me about tvOS.
No joke friends say to me: if formuler charges 100€ for the tvOS app - instant buy
D/loaded the app on IPad and IPhone 15.
The URL for server was accepted on IPAd but not on iPhone 15?
Firstly I tried on the 15 which was not accepted later I tried the same URl on IPad worked
Any help
*New update*
Version 1.0.2
- Added the ability to import content sources from Formuler device.
- Added screen fill gesture in video player. Pinch to zoom.
- Bug fixes and performance enhancements.
Hi Everyone,
I hope you’re doing well!
I just had a quick question regarding the iOS app and new update. So basically, I appreciate Formuler for bringing this new update to let you import the IPTV source via QR code. However, the problem after importing and refreshing the feed, I have been having issues with viewing the content, it continuously shows “An error occurred: -1” for live streams; “No Data” under VOD description page; and similar error as live stream under VOD player.
I would appreciate any help and support.
Hi Everyone,
Maybe your provider doesn't allow multiple connections at the same time using the same account? Try to talk to your provider about it.
Also try turning off your Formuler box and then refresh the content list in MOL+ and see if the issues persist.
Anyone find it odd that the free app can show multiple day epg but the z11 can only show 24 hours ![]()
You only see 24 hours in the Single EPG list view on Z11?
Yeah,on XC connection very weird,hope this will give devs insights to repair shortcomings on z11 box.
Everything works fine so far so good. Only thing sometimes its keeps buffering, but i guess when watching tv and the box is on and you turn the app on its stuttering, can't watch it together?
Depends on if your service provider allows multiple connections.
If you turn off the box and the problem goes away then you know where the issue is coming from.
Plz make the access to the full menu options in landscape mode available just as they are in Portrait mode. It is extremely annoying to have to tilt the device everytime you need to make a change.
Ok noticed that, i need to ask my provider to accept the mac adress for multiple connection. Hope in future to see the app also for macos for mac systems.
Over the last two years i have tried out between 15-20 providers,and they all showed limited grid epg of 24-36hours,on XC connection,so definitely not just provider related!
In single view can see days ahead. It’s in guide where it’s 24 hrs
Thank you Sam and the team and most certainly was worth the wait 😁
No option to Cast?
Hi friends,I have 2 buxes at home (z mini and z8pro.I have downloaded the app and installed.Now my question is how i can get it running with my subscription?.
No option to Cast?
No, at least not for now. Formuler just started with iOS App, we will see what feature options will come in next time.
If your provider allow multi use for your sub. and you already use this on the Formuler Boxes, then use same XC Login also on the mobile app.
Use the export feature on your Z mini. (This won't work with Z8pro)
Open Mytvonline3 > Main menu > Content sources > and click on the "Export Portal Data" button.
Follow the on-screen instructions
I am using iOS app on iPad Air 3 and can not see thumbnails in vod. It appears as black boxes.
Hello, i see this IOS app on apple store on my iphone, but not on apple store on my apple TV 4K ??
thanks for help
Is only for iphone and ipad, not for other Boxes or similar.
thanks for reply. is it foreseen on appleTV 4K ?
