Any eta for ios release? Will it take days, months or years? I have 5 colleague's who desperately want this app on their iPhone and are willing to pay but they don't want to switch from iPhone 15 pro (2x) or 15 pro max (3x) to Samsung only for this app. They've seen it working on my device and can't wait anymore
Mytvonline plus for IOS
- MYTVOnline+
- MYTVOnline+ iOS
Elroy -
November 26, 2023 at 8:22 PM
There is no date for now when the IOS version will be released. All of this is just at beginning.
Exactly 💯
Hopefully there will be a IOS version ASAP since i love MyTvOnline3. Lot of IOS apps are not that good
SAM hopefully it will be sooner than later it is a great app I had the chance to try it out on cheap android phone worked great awesome but as I use Apple phone for everyday use sure would be awesome for an IOS version of the app , making you guys the best IPTV innovators in the world which you pretty much are LOL
Thank you very much. It will come, all i can say for now, please patient.
Any idea when is coming for iOS?
Any news about a ios app in the make?
If you need any help testing it, please message me. I am a qualified software tester with 9+ years of experience.
We ask for your understanding that not all platforms can be covered at once. For this to happen it takes time and patience.
Unfortunately, Formuler doesn't have an armada of programmers and the ones they do have to cover all the many different projects.
It is planned and takes time to complete. We should hope to see it at the end of the year and be happy if it comes sooner.
We ask for your patience because it should get well. Thank you.
Well I’m another MyTvOnline user anxious for IOS support. I appreciate everything you folks do to bring us the highest quality and reliable applications!!
"By the end of the year"
I'm also willing to be beta tester
Ios is more difficult then android. Please be patience...
Still waiting and hoping this to be drop and we’re nearly at the end of the year, could we please have a update guys.
I think its coming begij or half 2025...
Please little bit more patience, it should not last long. You will like it
Thanks guys for your ongoing efforts
I have the box and i have mytvonline + on my tablet, can’t use anything else it’s a massive downgrade and iOS needs it, most definitely looking forward to it
STOP TEASING
shooooow screeeeens
and if you need a beta tester within testflight - no worries i would share my testflight email
Mytvonline+ is from today available on App Store, please install. We hope you will like it.
MYTVOnline+ IPTV PlayerMYTVOnline+ is the best media player to take your streaming sources on-the-go. IMPORTANCE: This app is a media player ONLY used to display and organize…apps.apple.com -
LETS GO
First feedback for ipad
Stream plays in LandscapeBut menu is only portrait mode
So i have to turn the device all the time.
Any plans for QR Scanner support like android version? Tried inputting my credentials manually (stalker) but it doesn’t seem to work. It asks for login info.
I tried troubleshooting and did the same for the android version. Inputting manually asks for login info but if I use QR scanner Stalker portal loads perfectly.
Christmas gift from Santa Formuler
Should come with next update.
For ios users, mytvonline should be in the appstore.😉
Hi now it’s available for iOS is there a way to rotate the screen so I can view content in landscape mode please? I’d like to view full screen landscape, thank you in advance
I saw this morning a message for Mytvonline, ios install it immediately.
I was very exited. 🤣Put my portal in did my settings.
I'm verry happy with this, no problems so far.
Thanks for who this app made all the credits to them.
We go for Holliday, so now I can watch 🤭
I got it from the app store.
I installed it on the ipad - I have the same problem as the previous Android one - live TV is ok, Films ok - series do not work. Failed to load VOD data? Apple and Android.
Any suggestions ?
Mytvonline,
Series - movies all working well no problems.
1 is the vikings
2 other Netflix series
3 movies back woods
Any suggestions ?
Maybe restart it, or the provider?
Mine is working well
Thanks for the ios-app.
I hope you can fix so it would be able to cast to a chromecast. Right now i dont find that solution. -
Copy and paste into the sources fields is not possible. Would make it easier if that would work. Thanks
Noticed that! Can't import/export portal because there is no valid QR scanner. Just what Sam says waiting for the next update so i can i add my tv list from the Z11 to the app.
PLAYS GREAT....
Om my iPad I have a button to paste:
Will come for ipad too, step by step. It just started and no rotation is already known.
Any suggestions ?
Create a support ticket using the Chatbot at https://support.formuler.tv
